Reformat ISY - Remove all.
I need to delete all the devices & programs from my ISY since I have moved, and the devices from the old house are now 'void'. Is there an easy way to reformat, other than possibly taking it apart and removing the SD card and reformatting it?
From the ISY users guide ... to do a factory reset:
• Use a sharp object to push in the Reset button (located below the ERR LED)
until the RX, TX, MEM, and ERR LEDs start flashing (once per second).
• Hold the Reset button for approximate 10 seconds, until the above LEDs turn
off and the MEM LED starts flashing quickly.
• Release the Reset button and wait for the ISY to reboot (when the MEM LED
stops flashing).
I must not have successfully reset it before when I tried that. I just did it again, and now I have a clean plate. Thanks!
Congratulations on the new home!
Be sure to reset the PLM as well.
To reset PowerLinc Modem to its original factory setting, unplug it from the wall outlet and wait 10 seconds. Press & hold its Set button, plug it
back in, continue holding the Set button for 3 seconds and then release.
After several seconds, the Status LED should turn on, indicating a reset is complete
http://www.smarthome.com/manuals/2413Sqs.pdf
Rand
