Setting a program to irrigate for set time with EZFlora
I've recently purchased and installed an EZFlora. I'd like to set up different programs where I can execute a program from my iPhone and not have to worry about forgetting to turn off my zones.
I've set up a simple program below that will irrigate each zone for 60 minutes. I was hoping you all could tell me if this will work. If it does, I'd like to set up different programs for different amounts of times, and different zone combinations.
       Set 'Irrigation / Veg Z1' On
       Wait  60 minutes
       Set 'Irrigation / Veg Z2' On
       Wait  60 minutes
       Set 'Irrigation / Cottage/Foundation' On
       Wait  60 minutes
       Set 'Irrigation / Japanese Garden' On
       Wait  60 minutes
       Set 'Irrigation / Japanese Garden' Off
That approach should work. The default maximum zone run time for each zone is 30 minutes. The maximum run time needs to changed using the Admin Console Set Options button for each zone. Otherwise the EZFlora will shut the zone off at 30 minutes.
Thanks! Glad to know it is a basic program.
I've already changed the maximum run time.
I would really like to Wait for a length of time set by a variable. Like:
Wait $Zone1_Time minutes
Then you only need to change the variable.
