temperature range inequalities
program set something
Status  'thermostats / MAIN - tstat -' > 23° (Temperature)
program reset something
Status  'thermostats / MAIN - tstat -' < 24° (Temperature)
I use Celsius by default.
Will the two inequalities above cover the entire range of temps, without an overlap, or do we have to account for fractional temps on the stats? If so, that is a problem as there is no greater than or equal, or less than or equal comparative.
Same question, different phrasing, are the tstat temps always reported (internally) as whole numbers?
You do have to account for fractional temps in the weather reports, but there you do have at least one of the greater/less than or equal constructs.
* Orest
