PWR LED on 99i erraticaly on/off...
Got mime 99i two days ago. All works fine - but the blue (yeah blue) PWR LED is erraticaly on/off. The device works fine regardless of the state of the PWR LED. Tried different power adapters, same issue. Any ideas?
Hello Jan,
Sincere apologies ... this must be a hardware defect. Please do be kind enough to request for an RMA and get the unit replaced.
To make sure you have a seamless transition, please make sure to backup your current ISY (File | Backup ISY) and then when you get the new one simply restore the backup (File | Restore ISY).
Micheal - thanks so much such a super-quick answer!
-Are you processing the RMAs or do I need to talk to the AARTech where I bought it?
-Is there any s/n series to avoid?
-My 99i has a plastic box and blue LEDs unlinke the images I see all over (metal box with green LEDs), is this model I need to avoid?
-Along with Keypad Linc this is the second :cry: component on my X10 jurney to Insteon that is DOA, very painful, probably the technology is not ready yet?
Jan
AARtech are very good to deal with for RMA's. I had a DOA SwitchLinc which they handled for me very well... sent me a return mailing label and everything.
