Rain Today (Weather Bug Module) finer resolution?
KSaccullo
Currently when using the climate module “Rain Today†parameter the ISY will only test (if statement) down to 1/10 of an inch.
The Weather module itself measures down to 1/100th of an inch.
Is it possible to get a finer resolution?
If .02, .04, .06 and .08 of an inch were added, in between values could easily be found.
example:
If greater than 0, and less than .02 then = .01
I’ still need to water the lawn if less than .1 of an inch, just not as much water.
