ISY-26 went crazy?
Apparently, last night my ISY-26 went crazy and decided to turn on a whole bunch of lights randomly. We discovered it this morning. This has never happened before. It's about 4-years old. Could it be reaching it's end-of-life? Are there any diagnostics I can run to see if it's functioning properly.
Kelly
How did you determine the ISY's role vs. power line noise, short outage & surge or accidentally pressed "all on" button? Did you perform a factory reset on the devices prior to installation or did you intentionally program an x10 address into them? How many of your neighbors are using x10 gear?
Obviously my sample size is smaller than Universal Devices', but all the unintended on issues I've worked with ended up being related to x10 signals one way or another--either a neighbor on the same house code or power line noise that looked to installed devices like a valid x10 command. I've never seen an ISY do that on its own.
Do you see anything strange in the Log or Error Logs?
Not sure what I'm looking at, but I did find the log of when the anomaly happened: Here are the details:
0 null Tue 06/14/2011 06:41:13 AM System Start
0 pool.nt Tue 06/14/2011 06:41:18 AM System -60001
Scene:My Lighting Status 0% Tue 06/14/2011 06:41:18 AM System Log
Fireplace Lamp-Right Status 0% Tue 06/14/2011 06:41:18 AM System Log
Fireplace Lamp-Right Status 0% Tue 06/14/2011 06:41:20 AM System Log
Fireplace Lamp-Right On Level 100% Tue 06/14/2011 06:41:20 AM System Log
Fireplace Lamp-Right Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:20 AM System Log
Floodlight - Left Status 0% Tue 06/14/2011 06:41:20 AM System Log
Floodlight - Left On Level 100% Tue 06/14/2011 06:41:20 AM System Log
Floodlight - Left Ramp Rate 2.0 Sec Tue 06/14/2011 06:41:20 AM System Log
Floodlight - Rear Status 0% Tue 06/14/2011 06:41:20 AM System Log
Floodlight - Rear Status 0% Tue 06/14/2011 06:41:21 AM System Log
Floodlight - Rear On Level 100% Tue 06/14/2011 06:41:21 AM System Log
Floodlight - Rear Ramp Rate 0.1 Sec Tue 06/14/2011 06:41:21 AM System Log
Floodlight - Right Status 0% Tue 06/14/2011 06:41:21 AM System Log
Floodlight - Right Status 88% Tue 06/14/2011 06:41:22 AM System Log
Floodlight - Right On Level 100% Tue 06/14/2011 06:41:22 AM System Log
Floodlight - Right Ramp Rate 0.1 Sec Tue 06/14/2011 06:41:22 AM System Log
Foyer 1-Front Porch Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 1-Front Porch On Level 45% Tue 06/14/2011 06:41:22 AM System Log
Foyer 1-Front Porch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:22 AM System Log
Foyer 2-Living Room Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 3-Lamp Post Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 4-Family Room Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 5-Garage Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 6-Morning Room Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 7-Outside Status 0% Tue 06/14/2011 06:41:22 AM System Log
Foyer 8-Inside Status 0% Tue 06/14/2011 06:41:22 AM System Log
MR 1 - Floor Lamp Status 0% Tue 06/14/2011 06:41:22 AM System Log
MR 1 - Floor Lamp Status 0% Tue 06/14/2011 06:41:23 AM System Log
MR 1 - Floor Lamp On Level 100% Tue 06/14/2011 06:41:23 AM System Log
MR 1 - Floor Lamp Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:23 AM System Log
MR 3 - Left Flood Status 0% Tue 06/14/2011 06:41:23 AM System Log
MR 4 - Right Flood Status 0% Tue 06/14/2011 06:41:23 AM System Log
MR 5 - Rear Flood Status 100% Tue 06/14/2011 06:41:23 AM System Log
MR 6 - Deck Lights Status 0% Tue 06/14/2011 06:41:23 AM System Log
Recessed Porch Lights Status 0% Tue 06/14/2011 06:41:23 AM System Log
Recessed Porch Lights Status 45% Tue 06/14/2011 06:41:24 AM System Log
Recessed Porch Lights On Level 45% Tue 06/14/2011 06:41:24 AM System Log
Recessed Porch Lights Ramp Rate 2.0 Sec Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Hall Switch Status 0% Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Hall Switch Status 50% Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Hall Switch On Level 50% Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Hall Switch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Foyer Switch Status 0% Tue 06/14/2011 06:41:24 AM System Log
Chandelier - Foyer Switch Status 50% Tue 06/14/2011 06:41:25 AM System Log
Chandelier - Foyer Switch On Level 50% Tue 06/14/2011 06:41:25 AM System Log
Chandelier - Foyer Switch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:25 AM System Log
Morning Room Fan Light Status 0% Tue 06/14/2011 06:41:25 AM System Log
Morning Room Fan Light Status 45% Tue 06/14/2011 06:41:25 AM System Log
Morning Room Fan Light On Level 45% Tue 06/14/2011 06:41:25 AM System Log
Morning Room Fan Light Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:25 AM System Log
Morning Room Lights Status 0% Tue 06/14/2011 06:41:25 AM System Log
Morning Room Lights Status 45% Tue 06/14/2011 06:41:26 AM System Log
Morning Room Lights On Level 45% Tue 06/14/2011 06:41:26 AM System Log
Morning Room Lights Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:26 AM System Log
Fireplace Lamp-Left Status 0% Tue 06/14/2011 06:41:26 AM System Log
Fireplace Lamp-Left On Level 100% Tue 06/14/2011 06:41:26 AM System Log
Fireplace Lamp-Left Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:26 AM System Log
Family Room Fan Light Status 0% Tue 06/14/2011 06:41:26 AM System Log
Family Room Fan Light Status 0% Tue 06/14/2011 06:41:27 AM System Log
Family Room Fan Light On Level 30% Tue 06/14/2011 06:41:27 AM System Log
Family Room Fan Light Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:27 AM System Log
Billiard Room Status 0% Tue 06/14/2011 06:41:27 AM System Log
Billiard Room Status 50% Tue 06/14/2011 06:41:27 AM System Log
Billiard Room On Level 50% Tue 06/14/2011 06:41:27 AM System Log
Billiard Room Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:27 AM System Log
Garage Lights-Exterior Status 0% Tue 06/14/2011 06:41:27 AM System Log
Garage Lights-Exterior Status 0% Tue 06/14/2011 06:41:28 AM System Log
Garage Lights-Exterior On Level 45% Tue 06/14/2011 06:41:28 AM System Log
Garage Lights-Exterior Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:28 AM System Log
Family Room-Right Status 0% Tue 06/14/2011 06:41:28 AM System Log
Family Room-Right On Level 100% Tue 06/14/2011 06:41:28 AM System Log
Family Room-Right Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:28 AM System Log
Family Room-Left Status 0% Tue 06/14/2011 06:41:28 AM System Log
Family Room-Left Status 0% Tue 06/14/2011 06:41:29 AM System Log
Family Room-Left On Level 100% Tue 06/14/2011 06:41:29 AM System Log
Family Room-Left Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:29 AM System Log
Living Room Lamp Status 0% Tue 06/14/2011 06:41:29 AM System Log
Living Room Lamp On Level 100% Tue 06/14/2011 06:41:29 AM System Log
Living Room Lamp Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:29 AM System Log
Scene:Outside Lights Off 0 Tue 06/14/2011 06:41:30 AM Program Log
Scene:Inside Lights Off 0 Tue 06/14/2011 06:41:30 AM Program Log
Scene:Chandelier-Foyer Off 0 Tue 06/14/2011 06:41:30 AM Program Log
Chandelier - Hall Switch Status 0% Tue 06/14/2011 06:41:31 AM System Log
Chandelier - Foyer Switch Status 0% Tue 06/14/2011 06:41:31 AM System Log
Scene:My Lighting Fast Off Tue 06/14/2011 08:28:32 AM Web Log
By the way the floodlights indicated in the log are fluorescent and can only be on or off (0 or 100%), but the log shows 88% which isn't even possible.
Hello kcrossley,
Do you have ELK?
Also, as far as 88%, in all likelihood the device to which the floodlights are connected is a dimmer and not a relay.
Hey Michel. Good to hear from you. You are correct. The switch is an 8-button KeypadLinc Dimmer,but the floodlights are connected to Smarthome In-LineLincs (Non-Dimming). What is an ELK?
Any insight on to why this happened? Do you think I should reset the ISY-26?
Kelly
Hi Kelly,
I do not think you need to reset ISY. If this random problem has not happened since, then I would just let it run as is. If it happens again, then we would want to see what characteristics the other occurrence has with the previous one. Currently, I think the problem is a faulty switch especially if you have KPLs version 2A or 2D.
ELK is a security system brand.
