johnnyt Posted July 18, 2011 Share Posted July 18, 2011 This is ask if you would consider support for the Midon Design Temp08 and its 1-wire temperature and humidity sensors. http://midondesign.com/TEMP08/TEMP08.html I read somewhere it supports AAG Electronica 1-wire weather stations but the post was dated and I don't see anything on the web site about it today. (I don't have one myself) Link to comment
Michel Kohanim Posted July 19, 2011 Share Posted July 19, 2011 Hi johnnyt, We do not support 1wire protocol. With kind regards, Michel Link to comment
johnnyt Posted July 19, 2011 Author Share Posted July 19, 2011 when I search for "1-wire" I don't get any hits. where can I get more info on how that can be done? Link to comment
Brian H Posted July 19, 2011 Share Posted July 19, 2011 http://www.1wire.org/ http://www.maxim-ic.com/products/1-wire/ http://www.maxim-ic.com/products/ibutton/ Link to comment
io_guy Posted July 19, 2011 Share Posted July 19, 2011 Or see here, some of us have started using 1-wire through WebControl: viewtopic.php?f=51&t=6470 viewforum.php?f=77 Link to comment
johnnyt Posted July 20, 2011 Author Share Posted July 20, 2011 The Temp08 takes care of the 1-wire protocol. Its output looks like this: SUN 16:52:46 Reading Sensors... Humidity #01[DC0000002B274726]=58% Voltage #01[520000002B25A826]=00.12V 05.05V Voltage #02[020000002B2CB326]=03.98V 05.03V Lightning #01[D4000000045C621D]=00020 24592 Temp #01[4C00080031220C10]=70.80F Temp #02[10000800312D2B10]=79.80F Temp #03[520000002B25A826]=76.21F Temp #04[020000002B2CB326]=72.77F Temp #05[DC0000002B274726]=76.21F It reads & reports on the following 1-wire sensors: (I only use temp/humidity stuff myself) Barometric Sensor DS2438 Counter Sensor (use for Lightning counts) DS2423 Humidity Sensor DS2438 Input Sensor DS2408 LED Sensor DS2408 Output/Relay Sensor DS2408 Rain Sensor DS2423 Temperature DS1820 DS18S20 DS18B20 DS1822 DS1900 DS2438 Voltage Sensor DS2438 DS2450 Wind Speed Sensor DS2423 The CAI WebControl board only handles 1 humidity sensor. I use 9 of the Midon Design MD3020E combo temp/hum sensor boards (http://midondesign.com/Sensors/sensors.html) with 4 installed in the enclosures described here (http://forums.homeseer.com/showthread.php?t=143452) to be able to control humidity related things like bathroom fans during a shower, the AC to dehumidify in the summer, the HRV to dehumidify in the winter, the furnace humidifier, and to turn off the HRV if the (calculated) humidex outside is above a certain level. io_guy, any interest in writing a windows program? (I only need the temp/humidity outputs.) Link to comment
io_guy Posted July 21, 2011 Share Posted July 21, 2011 io_guy, any interest in writing a windows program? (I only need the temp/humidity outputs.) It's a serial device so I'd probably have to have one in front of me to debug with. At this point I'm content with the WebControl so I can't see it happening. Sorry. Link to comment
