Strange Flickering
I'm hoping somebody has had some experience with this one.
I have a room of lights downstairs that flickers when I press any Insteon in the house.
It flickered a little when I had a regular dimmer on it when I pressed Insteon kpls swls etc...
but I chalked it up to a cheap dimmer.
I figured it would go away with the swl (latest model) but it's still there.
The room of ten lights is the only thing on the breaker.
I have the same lights all through the basement hooked up to Insteon and no other issues.
It also flickers when I'm programming with the Console.
I have an electrician who can come and check it out but I wanted to ask on the forum first.
Drew
To be sure that I am clear: You have a circuit with ten lights only. The ten lights were all controlled by a simple "regular, cheap" dimmer. The ten lights are now controlled by an insteon switchlinc. In both cases, the ten lights all flickered in response to any other insteon devices?
I have experienced some of the fancy Lutron switches react to insteon signals, but not simple "cheap" dimmer switches. I can only think that there is a loose wire somewhere.
  • 1 month later...
I brought a friend over who is a licensed electrician.
I looked at the system and said it didn't make sense either.
No loose wires or issues with anything he could find.
I replaced it with another SWL and it doesn't seem to do it.
The real test will be when I put that same SWL in another room to see if it flickers.
Then I'll know its the SWL.
Drew
I had the same problem localized to one room. When i turned on the ceiling fan the light would flick on then off. The switch would react though. It quit doing it after a while.
      37.1k
      371.5k
