tim2u Posted August 6, 2011 Share Posted August 6, 2011 In order for an ECM1240 standard kit to connect to ISY, what hardware/software is needed? Do I need to get the ECM1240 Zigbee modules then a Zigbee to ethernet adapter? Or can I connect to RS232 line directly with some Insteon module? I know I will need the ISY Brultech Add-in also. Also, I've read in forums that ISY supports all 7 channels. Does that mean I can monitor KWH on all 7 channels? If not, what info is available for all 7 channels on the ECM? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted August 7, 2011 Share Posted August 7, 2011 Hello tim2u, You need the EP1 which is Ethernet to Zigbee Bridge for Brultech. Yes, you can monitor all channels (including the kWh). With kind regards, Michel Link to comment Share on other sites More sharing options...
mathewbeall Posted September 15, 2011 Share Posted September 15, 2011 Link to comment Share on other sites More sharing options...
