values >,<,<=,>=
C Martin
I am confused and I know that this is a question that should have been asked a long time ago.
> evaluates as Greater Than,
>= evaluates as Greater Than or Equal to,
< evaluates as Less Than,
<= evaluates as Less Than or Equal To.
Is this correct, or am I backwards?
I seem to be getting reverse values.
Sorry if this seems to be a Juvenile question.
Clarence
Thanks apostolakisl,
But is ISY programming backwards?
I seem to get reversed results from my evaluations.
       Status  'Thermostats / Remote Stat / Remote Thermostat' < 84° (Temperature)
       $sRemote_Stat_temp_alert  = 1
       $sRemote_Stat_temp_alert  = 0
How would you evaluate this program?
I actually want my variable to evaluate to 1 if the temp is greater than 84.
This actually evaluates to 1 when the temp is 84 or even 83 - 84 or less.
Clarence
While I have yet to take advantage of the variables, I would evaluate your condition as:
Status  'Thermostats / Remote Stat / Remote Thermostat' IS LESS THAN 84°
Given this, your program would set your variable to "1" if the teperature is below 84 degrees. This appears to me to be consistent with every math convention that I learned.
Given this, I believe it would be more correct to write your condition:
Status  'Thermostats / Remote Stat / Remote Thermostat' > 84°
I guess my mind is working in reverse.
I agree with your statement.
I guess I needed to see through my fog.
Clarence
The symbol compares the two things on each side of it. The alligator eats the bigger number
For example:
1<2 4>3
So if you wrote
if
Status 'Thermostats / Remote Stat / Remote Thermostat' < 84° (Temperature) (in plain English you would say, "if the remote thermostat is reading less than 84 degrees")
then
else
Your variable would be set to 1 whenever the temp is less than 84 because that is when the if statement is true.
      377k
