Why doesn't ISY turn on a responder when controller toggled?
Firmware 2.8.16. I create a scene on ISY for an 8-button controller to turn on a dimmer responder. If I manually hit the controller button, the responder light turns on and off. When I use the ISY to turn the controller on or off, the responder does nothing.
I'm new to this so there might be an obvious answer/ISY bug/Insteon limitation--
Starmanj
Select the Scene name and turn the Scene On/Off. Turning an individual device On/Off with Direct commands does not then propagate to the Scene controlled by the device. Not the way Insteon works.
