Going Between Admin Console for Two Different Firmware Vers
Beyond pointing to the correct URL, is there anything which needs to be done when one has to go between Admin Consoles for ISYs with different firmware versions?
I have an ISY-26 running 2.7.15 and an ISY-99 running 3.1.9.
Do I need to clear the Java cache going between versions? Thank you.
Now that the Admin Console for ISY-26 is essentially "frozen", would it make any sense to load this as a completely separate app to remove the requirement for clearing the Java cache each time one goes between ISY's? I know this is an edge case for most people - who has two or more ISY's? An installer or maintainer perhaps?
