Lost My ISY-99i
I just installed an ELK M1 Gold and exported my device list and imported it to the ELK. I tried to turn on a light when I armed the system and it didn't work. Then I noticed I lost connection to my ISY. Now I can't get to my ISY at all. I tried to reset it to no avail. Any ideas?
Are you using static or dhcp? Is your last backup recent? You can try resetting with the reset button and restoring your isy but I would try that last. Try unplugging your plm from the wall and then replugging it back in and also check your network cable.
Turns out it was a dead port on my switch. Just seemed to happen at the wrong time. Thanks for the reply.
