Cannot add Scenes
What would prevent me from adding scenes? Everything else appears to be working correctly--I can add devices, query their status, control them, control scenes, programs are working--but I cannot add a scene. The last time I did this some months ago this was not a problem. Just upgraded firmware. Prior to that I was on 3.6.
Hello keepersg,
If you have 99i, you may have reached the limit of the number of nodes/scenes supported and must upgrade to PRO ($30.00). Apart from removing a scene and then adding one back, unfortunately, there are no other indications for this limitation.
Actually, I have the ISY 99 PRO. Exam of my file structure is similar to what is described in this post:
viewtopic.php?f=27&t=1951&hilit=isy+shell+commands
with all of the devices duplicated in 3 different my lighting top scenes.
I do have backups. Your advice and help would be much appreciated.
Hello keepersg, thank you.
I think the problem is that your SD Card is corrupted. What firmware version are you on? You have to make sure that you have a backup from any version NOT equaling 3.1.6 (which corrupted the backup files).
Once you have located a good backup, please go to File | Restore ISY. If you are still having issues with strange characters on the screen, please do our tech support line and we'll try to fix it remotely.
