mitch236 Posted October 25, 2011 Posted October 25, 2011 Since I'm not a programmer I'm not sure how to explain this but I would like it if I could install and run a program from within the ISY. Right now I'm using a program written by io_guy to allow communication between my DSC alarm and the ISY. Unfortunately, for the program to update the ISY, it has to be running on a PC which has to be on 24/7 and logged into (because the program can't be made to run as a service). It would be much better if I could somehow install the program into the ISY so it would run with the ISY and I wouldn't need to have it installed on a PC. If this is possible, I would think that would open up a whole world of improvements for third party programs that interface with the ISY like Mobilinc (which I also use). What do you think? Is this possible?
apostolakisl Posted October 25, 2011 Posted October 25, 2011 What you are asking for is a "module". Like the weatherbug module. It would have to be written into the firmware of the ISY. Or, the network module could be upgraded to allow for two way communication. I have also read on the forum that the Elk module may work with other brands (like dsc) in the future.
mitch236 Posted October 25, 2011 Author Posted October 25, 2011 Maybe what could be done is a Windows evironment module. That way, any program that interfaces with the ISY that runs in a Windows environment could be loaded into the ISY!
