ISY Firmware Version History
--- Version 1.5 ---
Support for EZIO and SocketLinc (EZIO analog inputs still do not work slated for 2.2)
AutoUpdate would not allow direct download from UDI Update Site (resolved)
Scheduler would wipe out on level and ramp rates on query (resolved)
--- Version 1.6 ---
Firefox workaround (closing ISY GUI closed Firefox)
Notifications caused a deadlock (resolved)
Performance improvements (communications)
--- Version 1.7 ---
Client standby caused ISY to hang (resolved)
Added more memory blocks to support more nodes
Performance improvements (network buffers)
--- Version 1.8 ---
GUI/Applet Enhancements:
Sessions are expired only when the number of un-ack'ed packets is more than 2
--- Version 1.9 ---
Support for manual addition of devices
Crawl network and add devices
Backup/Restore devices/PLM
GUI enhancements
--- Version 2.0 ---
Support for manually adding INSTEON devices by their addresses
The Ability to crawl and scan the network after a Link session or after adding a device manually. This operation finds all the devices linked to the added device and automatically configures them in ISY (if they are not already in ISY). Note that this function does NOT regenerate scenes/groups in ISY
Progress bar accuracy improvements
Incorporated Sub-Routine's recommendations vis-a-vis Ramp Rate and On Level. Now, Ramp Rate uses time instead of percentage while both On Level and Ramp Rate now have a tooltip text showing the exact value of the slider
Restore Device: simply fixes all the links in that device based on the settings in ISY
Restore All Devices: reprograms all devices based on the settings in ISY
Restore PLM: enables you to swap out a bad PLM and have ISY reprogram all the devices and the new PLM based on the settings therein
Incorporated an anonymous suggestion to change the Master/Slave to Controller/Responder while using buttons instead of a drop-down list
--- Version 2.1 ---
Support for more Cable/DSL routers
Confirmation dialog for Remove All for Triggers and Schedules
More granular Ramp-Rate settings
Fixed Date issue where May 31st was skipped
Fixed problem where GUI was not being updated
Fixed problem where occasionally a controller was linked as a ControlLinc
--- Version 2.2 ---
Fixed Intermittent startup trap error
Fixed Unidentified PLM caused deadlock
Startup performance improvements
File System performance improvements
KPL buttons can now be responders in scenes
Can now access ISY without a URL path (no need for /0/p)
Can now assign on level for relays in scenes (it was grayed out)
Added buttons to move to next/previous year in the Schedule/Time Configuration dialog
Can now add custom latitude/longitude
--- Version 2.3 ---
Bug Fixes:
XML Parse Error with certain firewall software
Fixed Lat/Long for Alberta, Canada
ISY hang after DHCP renew
Using a dynamic-DNS address would not get resolved when accessing ISY remotely
Extra html tags on the AutoUpdate dialog
Functional Enhancements:
Multi selection of devices to be moved into a scene
Support for KPL Toggle Mode
Support for KPL Synchronized Buttons
Support for one or more buttons from the same KPL as responders in the same scene
Support for Linksys Routers WRT54GS and DLink DIR-655
Performance improvements in system startup
Performance improvements in adding devices
Cosmetic Enhancements:
Changed the color to RED for a controller within a scene; everything else is blue
Left Nav bar widened to support long names
Changed the "Cancel" label to "Done" in certain dialogs
Added UDI Forum menu option to the Help menu
Progress bar:
- No longer Always on Top
- More accurate when clearing configuration before a Restore ISY
- More accurate after linking/adding/removing devices and scenes
  • 4 weeks later...
--- Version 2.4 ---
Bug Fixes:
Fixed the right mouse click on MAC/OSX
Fixed the file dialog on MAC/OSX
regression: adding a KPL/SWL manually (using the address) caused ISY to hang
Regression: removing devices left residue
The cross reference tree view did not reflect both Manages and Is Managed By relationships
Busy threads when no network connection (work-around)
All on/off on My Lighting and Network icons
All on/off from controllers such as ControLinc
Full support for RemoteLinc
EZRain timer support
All On/Off workaround
Replace Device
Remove PLM
Keep existing links
Merge existing links into ISY
Printable topology
Support for adding notes/locations to each device/node
Show default backup filename
The state of the window is now persisted between sessions
The state of the tree is now persisted between sessions
Different color for on status
Device addresses now closely match to those of Insteon
Autoupdate is now checked immediately (when system is not busy)
Autoupdate can now be invoked from the same dialog
