Unable to access ISY99 (was previously working fine)
My ISY99 (IR Pro) was working fine, but now I am unable to access it from my web page (http://192.168.0.18/admin). This morning when I tried to open the web site on my local network, I got the following two error messages:
Socket Open Failed java.io.IOException: Unable to establish loopback connection
XML Parse Error http://192.168.9.18:80/desc
the web page locked up Explorer, I rebooted the laptop and power recycled the ISY99, the first two times I tried to get in via the web brower, it locked up Explorer, I power recycled and rebooted the laptop again, now when I try to access via the web, the Universal page comes up but nothing happens? I have a keypad and can access the scenes off the ISY. The bottom blue light is on and nothing else and it appears to be recognizing Insteon commands (light blinks) off the KPL. I power recycled the cable modem/router which the ISY is attached, no joy? When the ISY initially locked up, I had the browser window up for maybe 3 hours.
Just successfully uploaded firmware 3.1.12 on Monday. Since I cannot get access to the ISY, unable to upload the new .13 firmward.
Any thoughts what to do next?
Thanks, John
Hi John,
It's possible that ISY's IP address has changed.
Would you please try the following URL:
http://www.universal-devices.com/99i/3.1.13/admin.jnlp
Yes the above works . . . I cleared the Java cache again and that got me back to the original IP address (which did not change). Seems that others have had similar Jave errors (see the firmware thread). I uploaded the new .13 firmware and all seems to be working well. Not sure what happened.
Thanks, John
