Time slips past sunrise
Hi! I'm a new ISY-99i owner and I'm still learning to program the device!
In particular, I'm trying to find the most elegant way to do the following:
1. Monday-Fridays, I want a particular my "Couch Lights" to turn on at 6:20 am and then shut off 10 minutes after Sunrise.
2. 7 days a week I want the same lights to turn on 30 minutes before Sunset and stay on until 10:30 pm at night.
I've condition #2 down, that one is straight out of the example in the manual. #1 however, I'm unsure what to do about the case when during the summer, Sunrise is earlier than 6:20 am. How do I make sure this condition doesn't end up turning on my lights at 6:20 am and then leave them on all day because Sunrise already past?
On Mon, Tue, Wed, Thu, Fri
From 6:20:00AM
To Sunrise + 10 minutes (same day)
Or (
From Sunset - 30 minutes
To 10:30:00PM (same day)
Set 'Couch Lights' On
Set 'Couch Lights' Off
One approach is to use a variable that indicates Sunrise and use that variable in the first part of the If. Define a Program that sets an Integer variable to a value of 1 Sunrise. Add a check of the Integer variable not equal to 1 in the first part of the If. Define another Program to reset the variable to 0 at Sunset.
Time is Sunrise
$IVar4 = 1
From 6:20:00AM
And $Ivar4 is not 1
Time is Sunset
$IVar4 = 0
Lee, how about 1 program for the variable instead of 2?
Time is from Sunrise
to Sunrise (Same Day)
$IVar4 = 1
$IVar4 = 0
Interesting. I'm not using version 3 yet (should I be worried about running Beta software if I'm still a beginner?) so I'm wondering if this technique can be used with a separate program, IsBrightOutside:
       From    Sunrise + 10 minutes
       To      Sunset  - 25 minutes (same day)
Then the main program uses it like this:
            From     6:20:00AM
        And Program 'IsBrightOutside' is False
    Or (
Is this the same thing?
Lee is on the mark.
I have a variable I call "Light.outside". It sets to 1 when the sun rises and 0 when the sun sets. So anything that you want to happen while the sun is up includes "if $light.outside is equal to 1" as one of the conditions.
so
$iLight.Outside is equal to 0
and
From 6:20am
To sunrise plus 30
Set couch light on
else set couch light off
One note, the light will get turned off at 6:20 if the variable is equal to 1 (or in other words, if 6:20 is after sunrise). You might not want that and if so you need to split the "off" part into another program.
Also please note, you need to use an integer variable. A state variable would trigger the program every time it changes and potentially run the program at unintended times or force an "else" to execute that you didn't want.
TJF1960
Single Program for variable control is a much better idea. Thanks.
oatflake
The V3 images are Betas so there is some exposure. The same thing can be accomplished using a Program True/False state as a binary switch rather than using a variable. There are many examples on the Wiki for using Programs as binary switches. That was the technique before variables coma along in V3.
Thanks for all your help. I decided to use a program instead of a variable since I'm not on V3 yet, and it seems to do the trick. Thanks for your help!
