apostolakisl Posted December 3, 2011 Share Posted December 3, 2011 Perhaps I am missing it, but I can't find anywhere in ISY to get Elk to sound the siren in any way. My ambition here is to have he siren chirp when I arm from the keyfob. Link to comment Share on other sites More sharing options...
apostolakisl Posted December 3, 2011 Author Share Posted December 3, 2011 Unless someone has a better idea, I think I am going to use one of the outputs as "chirp siren" and then set an Elk rule to chirp the siren when the output is tripped. Link to comment Share on other sites More sharing options...
LeeG Posted December 3, 2011 Share Posted December 3, 2011 Have you tried applying power to the sirens for a chirp test. My outside sirens would cause some unwanted attention if I tried to use the siren circuit the way I think you want. Link to comment Share on other sites More sharing options...
apostolakisl Posted December 3, 2011 Author Share Posted December 3, 2011 Have you tried applying power to the sirens for a chirp test. My outside sirens would cause some unwanted attention if I tried to use the siren circuit the way I think you want. Elk has a built-in chirp function that sounds about like your car chirp. Link to comment Share on other sites More sharing options...
LeeG Posted December 3, 2011 Share Posted December 3, 2011 Thanks for that information. Someday I may replace my old security system. It works so well I have resisted the idea of a change out. If it ain't broke don't fix it but with all the new capability of the ELK Module there is lots more temptation. Link to comment Share on other sites More sharing options...
apostolakisl Posted December 4, 2011 Author Share Posted December 4, 2011 So this is working perfect. Chirp Sirens Twice If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Elk Output 'Output 065' On for 1 Seconds Else - No Actions - (To add one, press 'Action') Chirp Siren WHENEVER Output 65 STATE IS TURNED ON THEN CHIRP THE OUTSIDE SIREN 2 TIMES I did not need an ISY program for this, I could have just written directly into any program to turn the output on for 1 second, however, since you can not name output 65 and higher I chose to write a program just so that it would have a name. I chose not to use lower than 65 on the off chance that I actaully buy one more output board and actually have 64 real outputs. This also works in reverse for having Elk tasks execute ISY programs. Just set Elk to turn on an output for 1 second and have ISY run the program whenever the output turns on. I think this little trick allows for the last few things that aren't fully integrated on their own to be functionally fully integrated. Link to comment Share on other sites More sharing options...
