Effective Forum Searching, KPL 2D Error, Topology
Hi,
What is the most effective way to search for forum postings related to a topic?
After reading the recent posting regarding a program that would intermittently trigger itself, and the response regarding the Keypadlinc 2D error, I tried searching the forums for this. The searches on the terms 'KPL 2D Keypadlinc' result in errors because the search terms are "too general". Really?
What is the KPL 2D error? I've heard it's the culprit for the sporadic communication error messages in the Admin Console. If I read related postings on other sites correctly, other control applications avoid these errors and other similar issues like the v35 Switchlinc errors. Is there a technical reason why the same can't be done with ISY?
How does one designate the load device for the topology feature in the Admin Console? The resulting webpage generated is a very, very handy map of an installation. BTW, I noticed some early Keypadlinc devices I have (v.1.3) have firmware versions reported as "v00" - is this normal?
Hi matapan,
Hi,
Search!
Try "keypadlinc v2d". Please note that each word should be at least 3 characters
You have to be much more specific as far as the applications that prevent these errors (which are communications between devices so I am not sure what applications can do to alleviate any of this). Any links?
Right mouse click on the node, choose Properties and then check the Load button
