LED Brigthness
Deleted: Did not want to clutter up a dev thread so I moved it to new thread.
LeeG,
Maybe that explains why it worked for me. I did a couple of restore devices when running 3.2.0 as well to try and get rid of some wonkiness.
Edit:
I should take the time to read your post properly. I was talking about the KPL. I had a hell of time with resetting the LED brightness on a Switchlinc. It finally worked when I did the restore under 3.2.0.
Hello all,
In 3.2.x, ISY has to migrate specific information about devices so that we properly apply different communication modes based on different devices.
There seems to be some corner cases where the migration might not succeed:
1. The information ISY already had was out of synch
2. ISY could not read the configuration
Do any of you see -1100x (.REC) errors in your Error Log starting from after the upgrade to 3.2.0?
Thanks Michel, LeeG,
Restoring did correct the problem with both the SWL and KPL. I never would have thought to try a restore since going back to an older image worked and then back to the new image it didn't work. Now to restore the other 50 or so devices.
Tim
Only 1100xx messages are these two when adding a non-I2CS FanLinc
Sun 2012/03/18 09:11:28 AM System -110022 /CONF/149CE9.REC
Sun 2012/03/18 09:11:28 AM System -110012 /CONF/149CE9.REC
Last night I noticed that my SwitchLinc LED Brightness is no longer responding after the upgrade to 3.2.1 (they worked under 3.1.17 - at least the ones in the following code):
       From     6:00:00AM
       To      11:00:00PM (same day)
       Set 'Master Bedroom / Bedroom Hall' On  6 / Off 1 (Backlight Level)
       Set 'Master Bath / VAN KPL / VAN KPL.A' On  7 / Off 2 (Backlight Level)
       Set 'Master Bath / Bathtub SLD' 100% (Backlight Level)
       Set 'Master Bath / Shower SLD' 100% (Backlight Level)
       Set 'Kitchen / KIT KPL Ceiling' On  7 / Off 2 (Backlight Level)
       Set 'Kitchen / Penninsula SLD' 100% (Backlight Level)
       Set 'Kitchen / Upper Hall-3Way' 100% (Backlight Level)
       Set 'Kitchen / Upper Hall-Load' 25% (Backlight Level)
       Set 'Living Room / LIV KPL / LIV KPL.A' On  7 / Off 2 (Backlight Level)
       Set 'Rec Room / REC Lamps' On  7 / Off 2 (Backlight Level)
       Set 'Rec Room / Ceiling Lower SLD' 25% (Backlight Level)
       Set 'Rec Room / Ceiling Upper SLD' 25% (Backlight Level)
       Set 'Master Bedroom / Bedroom Hall' On  0 / Off 0 (Backlight Level)
       Set 'Master Bath / VAN KPL / VAN KPL.A' On  0 / Off 0 (Backlight Level)
       Set 'Master Bath / Bathtub SLD' 1% (Backlight Level)
       Set 'Master Bath / Shower SLD' 1% (Backlight Level)
       Set 'Kitchen / KIT KPL Ceiling' On  0 / Off 0 (Backlight Level)
       Set 'Kitchen / Penninsula SLD' 1% (Backlight Level)
       Set 'Kitchen / Upper Hall-3Way' 1% (Backlight Level)
       Set 'Kitchen / Upper Hall-Load' 1% (Backlight Level)
       Set 'Living Room / LIV KPL / LIV KPL.A' On  0 / Off 0 (Backlight Level)
       Set 'Rec Room / REC Lamps' On  0 / Off 0 (Backlight Level)
       Set 'Rec Room / Ceiling Lower SLD' 1% (Backlight Level)
       Set 'Rec Room / Ceiling Upper SLD' 1% (Backlight Level)
Turn off KeypadLinc Backlights through the night and reset them in the daytime
My KeypadLincs are working but not the SwitchLincs - I will do some more testing tonight ...
Dwight
dstanley
The solution for now is to Restore Device. You can confirm this by running Tools | Diagnostics | Event Viewer with Level 3-Device communications events selected. Make an adjustment to the LED Brightness through the Admin Console. If the commands in the event trace are Set MSB,Peek,Poke run Restore Device. Then repeat the LED Brightness change and see if the commands have changed.
This is what the commands probably look like now .....
Wed 03/21/2012 03:05:53 PM : [iNST-TX-I1 ] 02 62 16 3F 93 0F 28 02
Wed 03/21/2012 03:05:53 PM : [iNST-ACK ] 02 62 16.3F.93 0F 28 02 06 SET-MSB(02)
Wed 03/21/2012 03:05:53 PM : [iNST-SRX ] 02 50 16.3F.93 19.70.06 2B 28 02 SET-MSB(02)
Wed 03/21/2012 03:05:53 PM : [standard-Direct Ack][16.3F.93-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 03/21/2012 03:05:53 PM : [iNST-TX-I1 ] 02 62 16 3F 93 0F 2B 64
Wed 03/21/2012 03:05:53 PM : [iNST-ACK ] 02 62 16.3F.93 0F 2B 64 06 PEEK (64)
Wed 03/21/2012 03:05:53 PM : [iNST-SRX ] 02 50 16.3F.93 19.70.06 2B 2B FF PEEK (FF)
Wed 03/21/2012 03:05:53 PM : [iNST-TX-I1 ] 02 62 16 3F 93 0F 29 80
Wed 03/21/2012 03:05:54 PM : [iNST-ACK ] 02 62 16.3F.93 0F 29 80 06 POKE (80)
Wed 03/21/2012 03:05:54 PM : [iNST-SRX ] 02 50 16.3F.93 19.70.06 2B 29 80 POKE (80)
This is what they should look like ....
Wed 03/21/2012 03:07:57 PM : [INST-TX-I2 ] 02 62 16 3F 93 1F 2E 00 00 03 C8 00 00 00 00 00 00 00 00 00 00 07
Wed 03/21/2012 03:07:57 PM : [iNST-ACK ] 02 62 16.3F.93 1F 2E 00 00 03 C8 00 00 00 00 00 00 00 00 00 00 07 06 (00)
Wed 03/21/2012 03:07:57 PM : [iNST-SRX ] 02 50 16.3F.93 19.70.06 2B 2E 00 (00)
LeeG - you just amaze me ... you are absolutely correct with your results.
I remotely ran the tests and received the exact results you posted. Since I am not physically at the location I will check out the LED's when I get home.
So - I should run the RESTORE DEVICE on all my SwitchLincs one at a time?
Does this affect any of the other devices?
Thanks for your help!
dstanley
Yes to running Restore Device on all the SwitchLincs one at a time. Probably a good idea to run on all the devices. A trace of one of my KeypadLincs shows the same situation. As it turns out the old Peek/Poke method continues to work on the one KeypadLinc I tested but it should be using the later I2 method. At this point there is not a good list of all the symptoms that are possible using Peek/Poke so running a Restore Device on each device, one at a time is a good thing to do IMO. The RF only devices such as Motion Sensors and TriggerLincs should not need a Restore Device as they never have supported I1.
Hi Tim, do you have any -1100xx errors in your Error Log? If you do, can you please send me your error log?
Hi Michel,
I had an error log covering 2 days that was 234 kb in size for image 3.2.0, sorry no -1100xx in the entire log.
So, what does that mean?
Tim
My program is working correct again ... SwitchLinc LEDs are being controlled again ... thanks!
