EZ-Flora and the ISY-99i
This question has probably been answered before but my attempts to search for an answer have been fruitless.
I have an ISY-99i running 2.8.16, the rest of my system config is listed below.
I recently installed an EZ-Flora 5010A module to replace my Rainbird unit. Initial checkout shows it is working as expected, however, there are some controls in the ISY admin console for the EZ-Flora that I don't understand:
1. What does FAST ON/OFF do with respect to the EZ-Flora?
2. What does the ramp rate and ON Level adjustment do with respect to the EZ-Flora?
System Config
Approximately 100 Insteon devices:
• Mainly Switchlincs, Lamplincs, Outletlincs, On/Off Adapters, etc etc
• 7 KPL’s
• Triggerlincs (2)
• RemoteLincs (3)
• Controllincs (2)
• ISY-99i
• Access Points (4)
• Dualband LampLinc dimmers (4)
• Signal Linc (2)
• Venstar Thermostats (3) with V2 RF interface
1. Fast On/Fast Off have the same effect as On/Off when controlling a Zone directly
2. Do not change On Level or Ramp Rate values. The corresponding bytes in EZFlora link records have different functions.
EDIT: Fast On/Fast Off have no effect on EZFlora Zones when used in a Scene command. The EZFlora is expecting On/Off commands only in Scenes.
LeeG,
Thanks for the reply. However, I have made changes to the ramp rate and ON Levels. Now I need to get them back to where they were before and make sure they don't get changed, right? Can I manually set them back? A factory reset?
Justin
Set On Level to 0% and Ramp Rate to 9 minutes. These values result in 00 00 in the first two data bytes in the Responder link record which is what the EZFlora is expecting for Zone control.
Got it, thanks!
Justin
