2472D Outlet Dimmer
Wondering if it is possible to configure the LED on the Outlet Dimmer? I know you can do it from the device itself, was wondering if ISY99i supported changing the setting.
On the Dual Band outlet link, the led is not dimmable from ISY.
In the manual it describes the process for adjusting the LED brigthness and if it is fully off or not.
Just saying... I have several, and there is no control in isy's gui to change it....
You must do this change locally at the outlet.
Teken . . .
Teken . . .
Ok, would be nice if isy could support changing it much like the SwitchLincs
