January 29, 200818 yr In an effort to simplify things for other people in my house, and try to save buttons on my remote, I've created addressable commands ie: Channel up = ON, Channel down = OFF, Volume up = FADE UP, and Volume down = FADE DOWN, (or close variations of those commands) for any selected device. I did this by assigning number buttons to a device ie: 1=front door, 2=rear soffit etc. etc. The numbered IR commands don't execute an insteon function, they merely run a program for a selected period of time, I chose 7 seconds, which then becomes false, see following example If IR '1' is Pressed Then Wait 7 seconds Run program 'IR address Front Door' (Else Path) Else - No Actions - (To add one, press 'Action') then the programs that actually execute the commands fade up, fade down, on or off If IR 'Volume +' is Held And IR 'Volume +' is not Released Then Set 'Front Door' Fade Up Else Set 'Front Door' Fade Stop are in conditional folders Folder Conditions for 'IR Front Door' Add conditions to limit when programs in this folder are allowed to run. If Program 'IR address Front Door' is True Then Allow the programs in this folder to run. I also like this for two reasons 1) because it's similiar to X-10 remote functions which I've become used to and 2) because it saves buttons on the remote (w/o addressing 6 devices times 4 separate commands = 24 buttons, vs. addressing where 6 devices + 4 commands = only 10 buttons
January 29, 200818 yr Thanks for sharing. I'll probably have time tomorrow, if all the anticipated precipitation occurs, to give this a shot. Rand
January 29, 200818 yr Excellent, Zellerman. It occurs to me that this idea may also be useful with other types of controls such as X-10 remotes, or Insteon controllers when the next release with FadeUp/Down/Stop is out!
