Cannot Remove Device
LarryF
I am using an ISY-26 with 45 registered devices, 5 of which are keypadlincs. After installing and registering an Insteon 2486D keypadlinc dimmer switch, I could not get it to progaram all of the buttons. I removed the switch and installed a brand new one and got the same result. When I tried to remove the original switch from the program, I got a failure. I then renamed the switch and tried to remove it again, still received a failure. I have the second switch installed and it operates correctly, but I cannot program the buttons. How can I elininate a device that is not responding correctly? When I attempt to remove the device it goes through 3 passes and on the 4th pass, at about 85%, I get a failure.
Hello Larry:
What versions are your KPLs? There are problems with version 1.6 KPLs being properly recognized and programmed by the ISY. Rumor has it that SH is working on a version 1.7 to fix these issues.
Best wishes,
LarryF,
I am so very sorry to hear about these problems you are having. In order to remove your KPL, please make sure:
1. It's plugged in
2. You can communicate with it (if not, factory reset your KPL and retry)
3. Please choose DBG 2 (telnet to your ISY) and then check the Java console to see what is failing
Hi Frank,
Thanks for responding. Unfortunately, the installation is about 125 miles away and I only get there once a month (next week). I have some of the older switches that I am not using and they are 1.4. The KPL that is in place is brand new, but will check when I get there.
Larry
Hi Michel,
Thanks for getting back to me. If I understand you correctly, the KPL must be physically installed in order to remove it from the programming. I will try this next week and let you know. I'm afraid I don't know what "DBG 2" is or where it is at. A little help on that would be appreciated.
Larry
Hi Larry,
Please see this post:
http://www.universal-devices.com/mwiki/ ... tion_Guide
And, if you need more information on how to telnet:
http://www.universal-devices.com/mwiki/ ... o_Your_ISY
Hi Michel,
Larry
Michel,
Will telnet work over the Internet or does it have to be used from the local network? I tried it remotely and got a failed connection.
Larry
Hi Larry,
Yes it does but you will have to open up port 126 on your router.
Michel,
Larry
      37.3k
      373.4k
