log file error (can't find code in user guide)
Got 2 strange errors when I saved a program tonight (the program saved okay so probably just a coincidence). I couldn't find them in the list of error messages on the wiki.
First, while the system was busy after the save, the attached screenshot shows a message about and open failed for an error log file. See attached screenshot below.
In the error log at around this time I got the following messages.
Thu 2012/01/26 07:44:35 PM System -170001 [uDSockets] HTTP:33 error:6
Thu 2012/01/26 07:44:39 PM System -170001 [uDSockets] HTTP:33 error:6
Thu 2012/01/26 07:44:44 PM System -170001 [uDSockets] HTTP:33 error:6
and a little later:
Thu 2012/01/26 07:52:24 PM System -170001 [uDSockets] HTTP:29 error:6
Thu 2012/01/26 07:52:29 PM System -170001 [uDSockets] HTTP:29 error:6
What do these things mean?
Hi johnnyt,
Please do send an email to support@universal-devices.com and let's setup a remote session. There's something either wrong with your unit or with how you have the programs running. I still do not understand why your system gets busy after each save unless there are many things running and causing heavy load.
Those errors basically mean that client, such as the Admin Console, sent a close notify but has not yet closed the socket properly. The only times those messages should cause alarm is if they are repeated every 10 seconds for more than 3 minutes.
I think I've found the problem for system busy after a save. I disabled my HomeSeer ISY plug-in and the system did not go busy after a save.
Now what? I guess I need to talk to the HS ISY plug-in developer but have you seen this before? Is there something I should tell him (or myself :) ) that would help me resolve this issue?
It does appear the HS ISY plug-in is causing the system busy message after a save as the programs are updated in HomeSeer. As I posted on HS forum and elsewhere here, while it prevents back-to-back saves, this particular issue is not a big deal.
RE: System -170001 [uDSockets] HTTP:33 error:6 at the same time. I'll assume the HS plug-in sent a close notify but has not yet closed the socket properly and that it has no impact on my system or its performance.
RE: Open failed for LOG/ERRORA.LOG. I'll assume this is not indicative of a problem with my setup.
Thanks.
