Programming dim levels
hello, VERY new to ISY.
When creating a program it only appears that dim levels under ACTIONS can be set in 10% increments. Is it possible, for example to set a device to 35%?
Thank you.
The best way to set a device level is to create a scene with that device in it. Then you can set the level within 1% and also set the ramp rate.
Have fun!
Rand
