Can a KPL button be a scene controller with a MS?
I have a scene that contains:
2 x ApplianceLincs as responders (of course)
1 x KeyPadLinc button A as controller
1 x Motion Sensor as controller
The idea being I can walk in the kitchen and the cabinet lights turn on, or if the Motion Dusk/Dawn is off I can turn them on with the button.
Never done this before but I was monitoring my ApplianceLincs in MobiLinc when I pushed the button to turn them on. The ApplianceLincs did not update to show they were on. The KeyPadLinc button lit up OK, just not the ApplianceLincs.
Just covered the MS to force Dusk/Dawn to turn on so I can see the effect when the MS turns the ALs on.
The MS drives a status update in ML but the button had no effect to turn the status off even though the lights went off. It appears the KPL button A is not causing an update to the scene in ML. However, when the MS timed out and went off the ALs then updated.
Thought this was a ML problem but noticed the Admin Console behaves the same. The KPL button does not drive the status of the other devices in the scene even though they physically work.
Hello Andy,
You should be able to ...
1. The first thing I check is to make sure the on level for ApplianceLinc is not set to zero in the scene for the KPL button
2. Do a link compare between ISY and the Device (Diagnostics | Show Device Link Table and Diagnostics | Show ISY Link Table) ... are they in synch?
3. And lastly, I would remove the KPL button from the scene and add it back to the scene
Michel, brilliant. I removed the KPL from the MS scene and re-added it. Now all is behaving as I expect.
Thanks so much.
