Insteon thermostat does not receive commands
I have brand new everything and have updated my ISY-99i Pro firmware to the latest release.
I am trying to install 2 Insteon 2441V Rev 2.3 thermostat adapters for my 2 Venstar T1800 (7 day programmable) thermostats.
I have no problem linking them and can query them without any issue as well. In face I have probably linked, deleted, rebooted and linked at least 10 times using 3 different procedures.
I can query them and get the exact thermostat settings so I know they are linked properly. The problem is that the thermostats do not respond to any ISY commands. Nothing I try changes anything on the thermostat.
The admin console acts like it is writing the changes to the device and displays all the proper progress bars, however the thermostat simply will not change any settings whatsoever.
Any help would sure be appreciated.
-Brian
It was actually not in off mode. I did not discover this requirement/suggestion until after looking for a solution. I have however, done factory resets on the 2441Vs and re-tried the entire procedure from the beginning with the thermostats in the off mode.
The odd part is that everything "appears" to work from the admin console side. I can query the thermostats fine and then results are always correct, and seemingly change the thermostats settings from the console and they appear to write to the device. But looking at the thermostat itself, nothing changes at all.
I got a little too complacent and did not check the ISY docs specifically for this device. After being stuck in "HomeSeer/X10 Hell" for the past 10 years, I decided to move to Insteon and the ISY-99. Everything has worked perfectly and I have had no problems thus far adding any type of device, and have more on their way.
-Brian
Ok, that's good to know if I get 'em working. So far, I have only set the thermostats to "off" or "heat" to test their ability to receive commands.
Posted on a similar topic...sorry for the dup's...
I have the same ones, though the 1 day version (didnt see the need for 7 day programmable ones with the ISY included).
They seem really sporatic at times, just doing status queries, but generally work. Maybe they need frequent polls?
Excellent! Last night I pulled the thermostats off and checked jumper settings, did factory resets all around, and had pretty much given up. I was just getting ready to call and get an RMA and send them back. I'll hold off. I really would like them to work.
I installed 3.2.2 with no issues, and it completely resolved the problem I had with the thermostat dongles. Everything works as it should now. All thermostat functions behave as expected. The only thing I needed to do was restore the devices after the upgrade.
Thank you very much!
      37.6k
      376.3k
