Fanlinc and KeyPadLInc
Hi Folks,
I thought this would work pretty easily w/o any programs. I have the fanlinc and the keypadlinc all hooked up. I have 4 scenes for the Fan (High, Med, Low, Off) and the respective keypadlinc button and the fanlinc-fan are part of the scenes. The scenes are then adjusted to High,Med,Low,Off.
When I activate the scenes from ISY, everything works as expected.
When I hit any of the KPL buttons (High, Med, Low, Off) the fan immediately goes to "On" - instead of the preset scene speed.
That is the first problem - and then the next is going to be to make sure that only one of the Keypad Fan lights is on at any given time - but I think I can accomplish that with a program.
Thanks in advance!
Matt
Click on the KeypadLinc button name listed below the Scene name in the My Lighting tree. The Scene Name (PLM is Controller) has a unique set of Responder On Level values which can be different from the Responder On Level values when the Controller is a KeypadLinc button.
That was indeed an easy fix! I thought I looked there, but obviously not... Thanks for the quick response!
Matt
