LampLinc 2-Pin and Dual Band KeypadLinc Relay Linking Issue
I'm trying to create a scene where the the main load on/off buttons of my Dual Band KeypadLinc Relay (2487S) act as a controller not only for their own load, but also for the new LampLinc 2-Pin (2457D2x Rev 1.6) module.
The ISY-99 can control the LampLinc 2-Pin by itself perfectly fine. On, off, dim, etc. all work as expected. However, when I try to add both of the above units to a new scene, with the KeypadLinc Relay being the controller, the LampLinc does not respond to physical KeypadLinc button presses or scene actions from within the Admin Console of the ISY.
Any idea what could be going wrong or how I can debug?
Thanks for the guidance.
What ISY firmware is being used?
How recently was the LampLinc and KeypadLinc purchased?
Suggest deleting the LampLinc and KeypadLinc from the Scene. Run Tools | Diagnostics | Event Viewer with Level 3-Device communications events selected. Add the LampLinc and KeypadLinc to the Scene, post the event trace.
I'm using firmware 3.1.17.
The KeypadLinc was bought in the last 3 months. The LampLinc was bought a week ago.
I'll work on getting the event log, thanks.
As requested:
Sun 04/01/2012 11:54:55 AM : [Living Room ] Start : Adding scene to ISY
Sun 04/01/2012 11:54:55 AM : [Living Room ] Finish : Adding scene to ISY was Successful
Sun 04/01/2012 11:54:55 AM : [All         ] Writing 0 bytes to devices
Sun 04/01/2012 11:55:19 AM : [Living Room R] Start : Adding to scene 'Living Room Scene'
Sun 04/01/2012 11:55:19 AM : [Living Room R] Making 'Living Room Scene' a Controller
Sun 04/01/2012 11:55:19 AM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 18 9C 88 01 2A 00 06
Sun 04/01/2012 11:55:19 AM : [18 9C 88 1  ] Link    1 : 0FF0 [A21F0CA763FF1F01] Saving  [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:19 AM : [Living Room R] Finish : Adding to scene 'Living Room Scene' was Successful
Sun 04/01/2012 11:55:19 AM : [All         ] Writing 8 bytes to devices
Sun 04/01/2012 11:55:19 AM : [18 9C 88 1  ] Querying engine version
Sun 04/01/2012 11:55:19 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 0D 00 06                 (00)
Sun 04/01/2012 11:55:19 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 0D 02           (02)
Sun 04/01/2012 11:55:19 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:19 AM : [18 9C 88 1  ] Retrieved engine version is i2
Sun 04/01/2012 11:55:20 AM : [18 9C 88 1  ] Using engine version i1 for 'Living Room R'
Sun 04/01/2012 11:55:20 AM : [18 9C 88 1  ] Link    1 : 0FF0 [A21F0CA763FF1F01] Writing [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:20 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:20 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:20 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:20 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F0 06          PEEK   (F0)
Sun 04/01/2012 11:55:20 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F0    PEEK   (F0)
Sun 04/01/2012 11:55:21 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 A2 06          POKE   (A2)
Sun 04/01/2012 11:55:21 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 A2    POKE   (A2)
Sun 04/01/2012 11:55:21 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:21 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F1 06          PEEK   (F1)
Sun 04/01/2012 11:55:21 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F1    PEEK   (F1)
Sun 04/01/2012 11:55:22 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 1F 06          POKE   (1F)
Sun 04/01/2012 11:55:22 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 1F    POKE   (1F)
Sun 04/01/2012 11:55:22 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:22 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F2 06          PEEK   (F2)
Sun 04/01/2012 11:55:22 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F2    PEEK   (F2)
Sun 04/01/2012 11:55:23 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 0C 06          POKE   (0C)
Sun 04/01/2012 11:55:23 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 0C    POKE   (0C)
Sun 04/01/2012 11:55:23 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:23 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F3 06          PEEK   (F3)
Sun 04/01/2012 11:55:23 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F3    PEEK   (F3)
Sun 04/01/2012 11:55:24 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 A7 06          POKE   (A7)
Sun 04/01/2012 11:55:24 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 A7    POKE   (A7)
Sun 04/01/2012 11:55:24 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:24 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F4 06          PEEK   (F4)
Sun 04/01/2012 11:55:25 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F4    PEEK   (F4)
Sun 04/01/2012 11:55:25 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:25 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 63 06          POKE   (63)
Sun 04/01/2012 11:55:25 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 63    POKE   (63)
Sun 04/01/2012 11:55:25 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F5 06          PEEK   (F5)
Sun 04/01/2012 11:55:25 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F5    PEEK   (F5)
Sun 04/01/2012 11:55:26 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 FF 06          POKE   (FF)
Sun 04/01/2012 11:55:26 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 FF    POKE   (FF)
Sun 04/01/2012 11:55:26 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:26 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F6 06          PEEK   (F6)
Sun 04/01/2012 11:55:27 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F6    PEEK   (F6)
Sun 04/01/2012 11:55:27 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:27 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 1F 06          POKE   (1F)
Sun 04/01/2012 11:55:27 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 1F    POKE   (1F)
Sun 04/01/2012 11:55:28 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B F7 06          PEEK   (F7)
Sun 04/01/2012 11:55:28 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B F7    PEEK   (F7)
Sun 04/01/2012 11:55:28 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:28 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 01 06          POKE   (01)
Sun 04/01/2012 11:55:28 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 01    POKE   (01)
Sun 04/01/2012 11:55:28 AM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 18 9C 88 01 2A 00 15
Sun 04/01/2012 11:55:28 AM : [PLM         ] Group  31 : Writing Controller Link matching [18 9C 88 1  ] Link    1 : 0FF0 [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:29 AM : [Living Room] Start : Adding to scene 'Living Room Scene'
Sun 04/01/2012 11:55:29 AM : [Living Room] Making 'Living Room Scene' a Controller
Sun 04/01/2012 11:55:29 AM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 19 26 61 02 1E 00 06
Sun 04/01/2012 11:55:29 AM : [19 26 61 1  ] Link   15 : 0F80 [A21F0CA763FF1F01] Saving  [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:29 AM : [Living Room] Making 'Living Room R' a Responder
Sun 04/01/2012 11:55:29 AM : [19 26 61 1  ] Link   19 : 0F60 [E201189C88FF1F01] Saving  [E201189C88FF1F01]
Sun 04/01/2012 11:55:29 AM : [18 9C 88 1  ] Link    2 : 0FE8 [A201192661FF1F01] Saving  [A201192661FF1F01]
Sun 04/01/2012 11:55:29 AM : [Living Room] Finish : Adding to scene 'Living Room Scene' was Successful
Sun 04/01/2012 11:55:30 AM : [All         ] Writing 24 bytes to devices
Sun 04/01/2012 11:55:30 AM : [18 9C 88 1  ] Using engine version i1 for 'Living Room R'
Sun 04/01/2012 11:55:30 AM : [18 9C 88 1  ] Link    2 : 0FE8 [A201192661FF1F01] Writing [A201192661FF1F01]
Sun 04/01/2012 11:55:30 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:30 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:30 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:30 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B E8 06          PEEK   (E8)
Sun 04/01/2012 11:55:30 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B E8    PEEK   (E8)
Sun 04/01/2012 11:55:30 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 A2 06          POKE   (A2)
Sun 04/01/2012 11:55:31 AM : [18 9C 88 1  ] Link    2 : 0FE8 [A201192661FF1F01] Saving  [..........FF....]
Sun 04/01/2012 11:55:31 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 A2    POKE   (A2)
Sun 04/01/2012 11:55:31 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:31 AM : [18 9C 88 1  ] Link    2 : 0FE8 [A201192661FF1F01] Saving  [............1F..]
Sun 04/01/2012 11:55:31 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B E9 06          PEEK   (E9)
Sun 04/01/2012 11:55:31 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B E9    PEEK   (E9)
Sun 04/01/2012 11:55:31 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 01 06          POKE   (01)
Sun 04/01/2012 11:55:32 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 01    POKE   (01)
Sun 04/01/2012 11:55:32 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:32 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EA 06          PEEK   (EA)
Sun 04/01/2012 11:55:32 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EA    PEEK   (EA)
Sun 04/01/2012 11:55:32 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 19 06          POKE   (19)
Sun 04/01/2012 11:55:33 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 19    POKE   (19)
Sun 04/01/2012 11:55:33 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:33 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EB 06          PEEK   (EB)
Sun 04/01/2012 11:55:33 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EB    PEEK   (EB)
Sun 04/01/2012 11:55:33 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 26 06          POKE   (26)
Sun 04/01/2012 11:55:34 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 26    POKE   (26)
Sun 04/01/2012 11:55:34 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:34 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EC 06          PEEK   (EC)
Sun 04/01/2012 11:55:34 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EC    PEEK   (EC)
Sun 04/01/2012 11:55:34 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 61 06          POKE   (61)
Sun 04/01/2012 11:55:35 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 61    POKE   (61)
Sun 04/01/2012 11:55:35 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:35 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B ED 06          PEEK   (ED)
Sun 04/01/2012 11:55:35 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B ED    PEEK   (ED)
Sun 04/01/2012 11:55:35 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 FF 06          POKE   (FF)
Sun 04/01/2012 11:55:36 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 FF    POKE   (FF)
Sun 04/01/2012 11:55:36 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:36 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EE 06          PEEK   (EE)
Sun 04/01/2012 11:55:37 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EE    PEEK   (EE)
Sun 04/01/2012 11:55:37 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:37 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 1F 06          POKE   (1F)
Sun 04/01/2012 11:55:37 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 1F    POKE   (1F)
Sun 04/01/2012 11:55:37 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EF 06          PEEK   (EF)
Sun 04/01/2012 11:55:37 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EF    PEEK   (EF)
Sun 04/01/2012 11:55:37 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 01 06          POKE   (01)
Sun 04/01/2012 11:55:38 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 01    POKE   (01)
Sun 04/01/2012 11:55:38 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:38 AM : [19 26 61 1  ] Using engine version i1 for 'Living Room'
Sun 04/01/2012 11:55:38 AM : [19 26 61 1  ] Link   15 : 0F80 [A21F0CA763FF1F01] Writing [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:38 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:38 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:38 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:38 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 80 06          PEEK   (80)
Sun 04/01/2012 11:55:39 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 22    PEEK   (22)
Sun 04/01/2012 11:55:39 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:39 AM : [iNST-ACK    ] 02 62 19.26.61 0F 29 A2 06          POKE   (A2)
Sun 04/01/2012 11:55:39 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 29 A2    POKE   (A2)
Sun 04/01/2012 11:55:39 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 81 06          PEEK   (81)
Sun 04/01/2012 11:55:40 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 1F    PEEK   (1F)
Sun 04/01/2012 11:55:40 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:40 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:40 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:40 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 82 06          PEEK   (82)
Sun 04/01/2012 11:55:41 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 0C    PEEK   (0C)
Sun 04/01/2012 11:55:41 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:41 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:41 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:41 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 83 06          PEEK   (83)
Sun 04/01/2012 11:55:42 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B A7    PEEK   (A7)
Sun 04/01/2012 11:55:42 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:42 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:42 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:42 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 84 06          PEEK   (84)
Sun 04/01/2012 11:55:43 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 63    PEEK   (63)
Sun 04/01/2012 11:55:43 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:43 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:43 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:43 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 85 06          PEEK   (85)
Sun 04/01/2012 11:55:44 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B FF    PEEK   (FF)
Sun 04/01/2012 11:55:44 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:44 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:44 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:44 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 86 06          PEEK   (86)
Sun 04/01/2012 11:55:45 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 1F    PEEK   (1F)
Sun 04/01/2012 11:55:45 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:45 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:46 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:46 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:46 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 87 06          PEEK   (87)
Sun 04/01/2012 11:55:46 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 01    PEEK   (01)
Sun 04/01/2012 11:55:46 AM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 19 26 61 02 1E 00 15
Sun 04/01/2012 11:55:46 AM : [PLM         ] Group  31 : Writing Controller Link matching [19 26 61 1  ] Link   15 : 0F80 [A21F0CA763FF1F01]
Sun 04/01/2012 11:55:46 AM : [19 26 61 1  ] Using engine version i1 for 'Living Room'
Sun 04/01/2012 11:55:46 AM : [19 26 61 1  ] Link   19 : 0F60 [E201189C88FF1F01] Writing [E201189C88FF1F01]
Sun 04/01/2012 11:55:46 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:47 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:47 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:47 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 60 06          PEEK   (60)
Sun 04/01/2012 11:55:47 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 62    PEEK   (62)
Sun 04/01/2012 11:55:47 AM : [iNST-ACK    ] 02 62 19.26.61 0F 29 E2 06          POKE   (E2)
Sun 04/01/2012 11:55:48 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 29 E2    POKE   (E2)
Sun 04/01/2012 11:55:48 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:48 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 61 06          PEEK   (61)
Sun 04/01/2012 11:55:48 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 01    PEEK   (01)
Sun 04/01/2012 11:55:48 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:49 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:49 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:49 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 62 06          PEEK   (62)
Sun 04/01/2012 11:55:49 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 18    PEEK   (18)
Sun 04/01/2012 11:55:49 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:50 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:50 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:50 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 63 06          PEEK   (63)
Sun 04/01/2012 11:55:50 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 9C    PEEK   (9C)
Sun 04/01/2012 11:55:50 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:51 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:51 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:51 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 64 06          PEEK   (64)
Sun 04/01/2012 11:55:51 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 88    PEEK   (88)
Sun 04/01/2012 11:55:51 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:52 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:52 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:52 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 65 06          PEEK   (65)
Sun 04/01/2012 11:55:52 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B FF    PEEK   (FF)
Sun 04/01/2012 11:55:52 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:53 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:53 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:53 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 66 06          PEEK   (66)
Sun 04/01/2012 11:55:53 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 1F    PEEK   (1F)
Sun 04/01/2012 11:55:53 AM : [iNST-ACK    ] 02 62 19.26.61 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:54 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:54 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:54 AM : [iNST-ACK    ] 02 62 19.26.61 0F 2B 67 06          PEEK   (67)
Sun 04/01/2012 11:55:54 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 2B 01    PEEK   (01)
Sun 04/01/2012 11:55:54 AM : [iNST-ACK    ] 02 62 19.26.61 0F 24 00 06                 (00)
Sun 04/01/2012 11:55:55 AM : [iNST-SRX    ] 02 50 19.26.61 0C.A7.63 2B 24 00           (00)
Sun 04/01/2012 11:55:55 AM : [standard-Direct Ack][19.26.61-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:55 AM : [19 26 61 1  ] Memory : EPROM Refreshed
Sun 04/01/2012 11:55:55 AM : [All         ] Writing 2 bytes to devices
Sun 04/01/2012 11:55:55 AM : [18 9C 88 1  ] Using engine version i1 for 'Living Room R'
Sun 04/01/2012 11:55:55 AM : [18 9C 88 1  ] Link    2 : 0FE8 [A201192661FF1F01] Writing [..........FF1F..]
Sun 04/01/2012 11:55:55 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 28 0F 06          SET-MSB(0F)
Sun 04/01/2012 11:55:55 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 28 0F    SET-MSB(0F)
Sun 04/01/2012 11:55:55 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:55 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B ED 06          PEEK   (ED)
Sun 04/01/2012 11:55:56 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B ED    PEEK   (ED)
Sun 04/01/2012 11:55:56 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:56 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 FF 06          POKE   (FF)
Sun 04/01/2012 11:55:56 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 FF    POKE   (FF)
Sun 04/01/2012 11:55:56 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 2B EE 06          PEEK   (EE)
Sun 04/01/2012 11:55:57 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 2B EE    PEEK   (EE)
Sun 04/01/2012 11:55:57 AM : [standard-Direct Ack][18.9C.88-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 04/01/2012 11:55:57 AM : [iNST-ACK    ] 02 62 18.9C.88 0F 29 1F 06          POKE   (1F)
Sun 04/01/2012 11:55:57 AM : [iNST-SRX    ] 02 50 18.9C.88 0C.A7.63 2B 29 1F    POKE   (1F)
Sun 04/01/2012 11:55:57 AM : [All         ] Writing 0 bytes to devices
The KeypadLinc is not likely I2CS. The LampLinc could be I2CS being in the last week or two. I think a better trace would be of adding the LampLinc to the ISY. Delete the LampLinc, run Tools | Diagnostics | Event Viewer with Level 3-device communications events selected. Then add the LampLinc.
Just looked at the event trace. Thanks, that answers the question.
Device 18.9C.88 is an I2CS device. Move to 3.2.2 to use that device.
EDIT: the device will have to be Deleted and added back under 3.2.2
Excellent, that worked! I thought about going to the beta version to try to resolve the issue, but ultimately decided not to until you suggested it. I'll have to do some research on I2CS. I haven't heard of it before today.
Thanks for the help!!!
SmartLabs is updating the Insteon protocols. This one is referred to as I2CS because it adds a CheckSum (CS) to some of the Insteon messages to improve message validation. There are other changes as well. Many devices being shipped now require I2CS support. Motion Sensor, FanLinc, SwitchLinc, LampLinc are some of the ones that have surfaced in the last few weeks with I2CS. I expect all the devices will eventually evolve to I2CS.
