Error Messages during reboot a problem?
My ISY with latest official release (3.1.17) was getting many errors attempting to sync with NTP service so I reboooted it. ISY restarted with normal query all sequence but then it displayed an additional very slow moving work in progress bar (about 10 minutes to get to 100%). I have a program that sends me a text message at startup so I can review a couple program states and the text message did not arrive until after the progress bar finished so I took a quick look at error log to see if something was wrong and found the following: (BTW I get error messages about opening elk files even though I do not have the module ... no big deal unless it suaggests something larger)
Time User Code Message
Wed 2012/04/18 08:52:46 AM System -170001 [HTTP] Socket not active#2 30
Wed 2012/04/18 08:52:48 AM System -170001 [HTTP] Socket not active#2 33
Wed 2012/04/18 08:53:04 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:53:25 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:53:51 AM System -170001 [HTTP] Socket not active#2 33
Wed 2012/04/18 08:54:16 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:54:40 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:55:05 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:55:30 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:55:54 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:56:19 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:56:39 AM System -170001 [sLF] FileOpen Failed: /CONF/ELK.CNF
Wed 2012/04/18 08:57:33 AM System -170001 [HTTP] Invalid socket 30
Wed 2012/04/18 08:57:58 AM System -170001 [HTTP] Invalid socket 30
Hello hart2hart,
The first thing I recommend is upgrading to 3.2.4 so that we have the same point of reference.
Looking at the logs, it seems that there are major network connectivity issues. Invalid socket means that the ISY is acting on a socket that has already been closed. This means two things:
1. Something is bombarding ISY with traffic
2. Port forwarding issues where by traffic destined for another devices is directed at ISY
After upgrading to 3.2.4, I suggest the following:
1. If you have any port forwarding rules, please do make sure they point to ISY
2. Telnet to ISY, and then issue DON ... this turns debugging on. Let it run for a couple of days and then send your Error log to support@universal-devices.com
Michel:
I upgraded to 3.2.4. However, I don't have old laptop (win XP) to access ISY which had telnet. I'll have to find another telnet program for Win 7? Been so long ... do I need to telenet in via rs232 or can I go in via IP address?
Paul
I have seen a post somewhere that explains Telnet does not come standard on W7 but it can be installed as an option. Cannot confirm this personally. I did find this with a Google search for windows 7 telnet
From Windows 7 Help:
By default, Telnet is not installed with Windows, but you can install it
by following the steps below.
To install Telnet Client
Click the Start button , click Control Panel, and then click Programs.
Under Programs and Features, click Turn Windows features on or off. If
you are prompted for an administrator password or confirmation, type the
password or provide confirmation.
In the Windows Features dialog box, select the Telnet Client check box.
Click OK. The installation might take several minutes.
  • 3 months later...
Hello,
Was there on outcome to the problem where it appears ISY is attempting to log into Elk even though there isn't an Elk system.? I have I'm having the same trouble.
Hello automateit,
Are you referring to:
If so, then this is NOT ISY attempting to communicate with ELK. This is a benign error when you go to the configuration screen and ISY cannot find an ELK configuration. You can ignore it.
If this is not the case, then would you please let me know what makes you think ISY is trying to communicate with ELK?
Michel:
I know it has been a while but, I wanted to clean up several things before I took you up on offer to look at error log. I've implemented DSCLink (working great since Firewall rules updated) and revised all external ports out of range of normal ports. Log has been sent via email and contains a couple days. ?
Paul
