DOA ISY-994i? Red light blinking
I received my ISY-994i pro ir today and plugged it in to find that the error light (red led) is blinking. A little googling told me that this is an indicator of a bad SD card. I opened the SD card slot to look inside and found there is no SD card. Is this normal?
I cannot access the ISY-994i on my network. I don't even think it's pulling an IP address.
Is there any other LED blinking. My 994i will blink red if there is no Ethernet connection. Make sure the Ethernet and Port A connections are not reversed. I have no external opening for an SD card which makes me think there is none.
Lee, My ISY994i has a small plasitc snap on cover on the front marked. "MicroSD" next to the red error LED. I have never peeked inside it.
uffy - I was wrong. After taking the 994i off the wall I do have a Micro SD card behind the small cover next to the Red Error LED.
Thanks Brian. I had looked for something larger along the sides like the 99i has with a similar case. Should have removed it from the mounting to see the front better.
You should have a micro SD card behind the cover.
You may want to contact the vendor you bought it from.
Though I know UDI's support is second to none and they may post some added thoughts.
