February 10, 200818 yr Just finished trying out my 99ir. Works great. Got a few switchlincs connected, and everything is working groovy. Now I'm trying to access via the internet. I have enabled UPnP on my PC (I have a Buffalo AirStation). When I try going to http://my.external.ip:ISYport#/0/x, I get a 404 Not Found error. Am I doing something wrong? Not sure if this is related, but when I try accessing my ISY via My Lighting through My Network Places, I get an error window which says that the device is offline.
February 11, 200818 yr Hello ResIpsa, If you've setup your remote access using ISY, then the combination of not being able to access it from My Lighting icon and remotely makes me suspect a firewall software on your system. If you wish, you can send me your URL (support@universal-devices.com) and I can check it out for you. With kind regards, Michel Just finished trying out my 99ir. Works great. Got a few switchlincs connected, and everything is working groovy. Now I'm trying to access via the internet. I have enabled UPnP on my PC (I have a Buffalo AirStation). When I try going to http://my.external.ip:ISYport#/0/x, I get a 404 Not Found error. Am I doing something wrong? Not sure if this is related, but when I try accessing my ISY via My Lighting through My Network Places, I get an error window which says that the device is offline.
