Enable Internet
I recently upgraded to latest firmware for ISY been using conductor but it went stale for a bit on my end didn't have a use for a while, Now it summer and I would like to use it again but.... when I try to enable internet access it fails. I have my router setup to let port 1443 through. I can login in locally also but when I type 99.99.99.99:1443 connection times out fom any outside source. FYI the IP is not mine and I do know I need my correct IP. I had it working for the longest time and have not made any changes to router or ISY with the exception of firmware upgrades. In the config page I have https port 1443 and http port 80 with the correct IP. One last piece of info I do not have port 80 open in router for ISY but I do have it for another ruel for my server, and don't think I have to or can make it a ruel for both or if thats even revelent. Any help would be great thanks.
I have at&t uverse router I have even tried to put the ISY in dmz mode which allows ALL traffic and still no luck so I don't think its a issue with my router. I did both, when I go file/enable internet I get failed Internet access. I also did go into the router and set the rules up but that was a long time ago and nothing has changed. I know in the one pic shows not connected but it is, because I can get email alerts, I sent my self a test and it went fine, as well as showing the correct IP. I hope this all helps, I'm kinda lost as why the ISY would have lost internet connection, and by no means am I saying its Universal Devices fault, probably something I did or at&t but I do think all my settings are in place correctly. Thank You
