Device Icon is Scene controller ?
Hi Wes-
In another thread: viewtopic.php?f=27&t=8778&p=66890#p66890 (Page 2) it was discovered that the device icon on a device page (not a scene page) will control an entire scene that the device is a member of rather than just the device itself. If this expected behavior or a bug ?
-Xathros
Hi Xathros,
This is the correct and intended behavior and here's why:
The idea is that if you use the ICON controls or switch control (graphic controls) in MobiLinc HD, the action (ON, OFF, etc) should reflect what the real-world device would do if you walked up to it and performed the same ON, OFF, etc action.
In the case where devices are controllers of a scene, that means the scene actually gets the ON, OFF, etc command, just like it would in the real-world.
If you want to talk just to that device (direct device commands) then you can tunnel into the details of the device and issue the ON, OFF, etc commands from the table menu here to talk just to the device.
I'll post this on the other forum you linked to, thanks.
Wes
