Java / Creating Floor Plan
Hi all
When I try to create a floor plan thru the admin console....I first end up with this..
and soon falls apart "somewhere" resulting in
Exception in thread "Thread-21" java.lang.NoClassDefFoundError: com/universaldevices/floorplan/UDAbstractFloorPlanScene
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.universaldevices.ui.UDMenuSystem.performAction(Unknown Source)
at com.universaldevices.ui.UDMenuSystem$1.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.universaldevices.floorplan.UDAbstractFloorPlanScene
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 4 more
Anyone know a LOT more than me about java related stuff....the address which Java seems to want me to login into there looks a little bizzzzzaaaaar. I assumed I was supposed to be using UN/PW for ISY
Java 6 Standard Edition Version 6 Update 31 (build 1.6.0_31-b05)
Cheers and thanks in advance
PLCG
Hello PLCG,
I am so very sorry to hear. Please bear in mind that the floorplan is legacy code that will eventually be removed. So, please do not count on it.
Now, please do the following:
1. Clear your Java cache
2. Go to http://www.universal-devices.com/99i/admin.jnlp ... this will install an icon on your desktop which you can use to launch the Admin Console
Please let me know if this helps.
That's ok.....thanks Michel
PLCG
