Water Sensor and ISY
Hello everyone,
I purchased smarthome http://www.smarthome.com/71940/Minotaur-Engineering-WSI1-Water-Moisture-Sensor/p.aspx and
http://www.smarthome.com/2450/IOLinc-INSTEON-Low-Voltage-Contact-Closure-Interface-1-In-1-Out-/p.aspx.Does anyone have experience in programing this with email notification? I mounted the sensor to concrete and when it starts to dry it switches from on/off multiple times causing it to send 50 or more emails.I tried this:
FLOOD SENSOR ON
       Control '0B-IOL-Basement sensor-Sensor' is switched On
       Set '01-AL-Pantry flood siren' On
       Send Notification to 'Tim/Al Aldeman' content 'BASEMENT WATER SENSOR'
FLOOD SENSOR OFF
       Control '0B-IOL-Basement sensor-Sensor' is switched Off
       Stop program 'Flood Sensor on'
       Disable Program 'Flood Sensor on'
       Wait  3 hours
       Enable Program 'Flood Sensor on'
       Send Notification to 'Tim/Al Aldeman' content 'AL's Sensor Enabled'
to turn it off.Does this look correct.I just added the
And I waiting for the customer to wet the sensor again because I received another 50 emails when the sensor switched to off,so I am trying to stop the program before I disabled it.
Or does any one a simpler way or am I using the correct sensor to accomplish this?
Thanks Tim
I would suggest setting a variable as a "blocker"
Basically like this.
     and
       $wateremail is 0
       $wateremail = 1
       Run program 2 then clause
PROGRAM 2
       blank
       wait 6 hours
       $wateremail = 0
This would send you no more than one email every 6 hours. You can adjust the time to suit your needs.
Thank you apostolakisl
I will try that Thanks for your reply.I will keep you posted.
Tim
Hi apostolakisl
Everything is working fine Thank so much for the help!
Thanks Tim
