Catching errors
On occassion, I get errors where ntp service or weather bug has stopped responding. The error log will be full of errors when I notice and look. Is there a method to catch these errors in a program so I could for example send myself a text to investigate service issue?
Hi hart2hart,
The short answer is no. This said, are the errors DNS related or connection related?
http://www.universal-devices.com/mwiki/ ... r_Messages :
-140000 	HTTP_CLIENT_DNS_ERROR
-140001 	HTTP_CLIENT_BASE64_ENCRYPTION_FAILED
-140002 	HTTP_CLIENT_CONNECTION_TIMED_OUT
-140003 	HTTP_CLIENT_WRITE_HEADER_FAILED
-140004 	HTTP_CLIENT_WRITE_BODY_FAILED
-140005 	HTTP_CLIENT_READ_RESPONSE_FAILED
-140006 	HTTP_CLIENT_HEADER_NO_STATUS
-140007 	HTTP_CLIENT_RESOURCE_MOVED
-140008 	HTTP_CLIENT_REQUEST_FAILED
If DNS, then you could have a reminder email every 24 hours and when it does not arrive, then you can assume the DNS problem has started again.
And, the main question is: why would you have these problems? What's your firmware version? Do you have Internet connectivity issues with other devices?
Michel:
First, I'm on latest firmmware 3.2.6 and don't have regular network issues?
I've seen the issue(s) surrounded by DNS errors and I just reboot ISY. On most ocassions, weatherbug or time have stopped reporting and all other network connections are working .... I run test email/txt program and I can connect wity Mobilinc, ISYajax and PC.
In future release, could some of the system errors be exposed to programs (with me including controls to keep from getting a 1000 txt messages when there is general network failure -- oh wait that won't happen :wink: )? Maybe we could work with io_guy to have a heartbeat variable monitor program in reverse like DSCLink from a supervising PC and it could send txt message? io_guy are you tunned in?
Just moved to DSCLink and that allowed me to retire current HomeSeer so I'm now using ISY for total HA. As usual working fantastic.
Paul
