HELP! :: ~ Best way to link switches
Hello, I am new here. I want to know the best was to link a slave switch to a master switch using the ISY-99i software. Can this software support this, or do I need to do it manually? I would like the LED light settings on the switch to match the master and all the slaves.
In case you are confused by that link, you want to learn about Scenes. Linking two switches is called a scene in ISY world. If you have an ISY, always do all linking through the ISY, or the ISY will have no way to know about the links and you loose all the cool ISY features like restore device, restore PLM, and programs that operate based on the condition of those switches.
  • 3 months later...
Never manually link devices together if you have an ISY99i or ISY994i.
Any manual linking done. Will not be known by the ISY991 controller and you will eventually mess up the links in the modules or PLM.
