Autelis Pool Control for Pentair EasyTouch w/ ISY 2-Way
autelis
We now have a Pool Control product compatible with Pentair Intellitouch and EasyTouch systems.
This device allows you to see the status of and control your pool equipment through your Pentair Intellitouch or EasyTouch control system. With ISY 2-way integration, you will have current pool status information stored in ISY variables including temperature readings and equipment status. You will also be able to send control commands to Pool Control from ISY using network resources. These features require the ISY network module.
Other features of Pool Control include:
- Web-Enabled
- Built-In Mobile App
- View and Adjust Temperature
- Turn Equipment On/Off
- Detailed Status Information
- Create and Adjust Programs
- Adjust Color Lights
- E-mail Alerts
- Helpful Service Reminders
To read more about pool control, please see the following links:
Product Page
Product Wiki
ISY Integration Details Page
What are the requirements for the EasyTouch firmware, if any? The reason I ask is because I have an early 2007 EasyTouch on firmware 1.0.6.0 and I know if I wanted to use Pentair's ScreenLogic system, I would have to get a new EasyTouch control board that would support firmware 2.0.0.0 and above. I want to know if the same requirement applies to the Autelis system before I purchase.
Dave
Thanks for your question. We have only tested the system with EasyTouch 2.0+ firmware but would be willing to work with you to add compatibility for the older 1.0 systems. You would simply need to order a unit and perform some tests using a special firmware we will provide. If there are any issues with achieving compatibility, you will be able to return the unit for a refund.
