Cycle Complete
I am trying to understand what is going on with the weather bug variables. I have read the various threads and I think I understand the basics.
So if I understand things, "Irrigation requirement" variable is the amount of water you want to add back into your yard. The "Cycle Complete" will subtract the amount of water specified in the "water applied per irrigation cycle" from the current "Irrigation requirement".
However I do not seem to be getting this behavior. I am calling the "cycle complete" each at the end of my irrigation program. But the value just keeps going up every day. It does not seem the "Cycle complete" is doing anything
In the weather bug program, I have set the "water applied per irrigation cycle" to .5
this is my basic program:
Time is 11:00:00PM
And Module 'Climate' Irrigation Requirement >= 0.5 inches
Send Notification to 'Default' content 'irrigation stats'
Set 'irrigation / Lawn Back center' On
Wait 5 minutes
Set 'irrigation / Lawn Back edges' On
Wait 5 minutes
Set 'irrigation / Lawn Front' On
Wait 5 minutes
Set 'irrigation / Lawn Entry Way' On
Wait 5 minutes
Set 'irrigation / Bamboo Entry Way' On
Wait 5 minutes and 5 seconds
Set 'irrigation / Bamboo back' On
Set 'irrigation / Garden' On
Wait 6 minutes and 5 seconds
Set 'irrigation / slope' On
Set 'irrigation / horsetail planter' On
Set 'irrigation / Side Window Planter' On
Wait 2 minutes and 5 seconds
Set 'irrigation / Side Window Planter' Off
Irrigation - Cycle Complete
However after one week of running this program the value of "Irrigation requirement" just keeps going up. It does not look to me that the "cycle complete" is doing anything. I am kind of stumped.
Day7
ET 0.3828 inches/day
Irrigation requirement 1.4673 inches
Water Deficit yesterday 0.2471 inches
Day6
ET 0.359 inches/day
Irrigation requirement 1.3852 inches
Water Deficit yesterday 0.2688 inches
Day5
ET 0.3705 inches/day
Irrigation requirement 1.1507 inches
Water Deficit yesterday 0.2887 inches
Day4
ET 0.3313 inches/day
Irrigation requirement 0.9519 inches
Water Deficit yesterday 0.2843 inches
Day3
ET 0.4178 inches/day
Irrigation requirement 0.8325 inches
Water Deficit yesterday 0.3771 inches
Day2
ET 0.2721 inches/day
Irrigation requirement 0.6203 inches
Water Deficit yesterday 0.2708 inches
Day1
ET 0.3625 inches/day
Irrigation requirement 0.5145 inches
Water Deficit yesterday 0.3777 inches
Hi jdunne,
The problem is that the Wait statement can be interrupted and, in fact, it's being interrupted. By this I mean that when the condition turns false (say, it's no longer 11:00 PM + grace period), then ISY will interrupt the Wait that it was waiting on and stops the program altogether.
I suspect some of your zones are not being watered either.
If you have to use Wait statements, then what you need to do is to make another program WITHOUT any conditions and have this program call Run Then on it.
Thanks Michel,
could I also just add a for statement to the if condition? That is say if 11PM, for 2hrs
That would extend the grace period with plenty time to spare (2 hrs)?
Hello jdunne,
You could, but the other possible issue would be if the "'Climate' Irrigation Requirement" changes while the program is running it would start the program over again so what has been watered would be watered again.
Michel's suggestion of breaking the program into two is your best option for non-interrupted watering.
Tim
