Marking a remotelinc
What do you use to mark the buttons on your remotelinc? I've tried a so called permanent marker, but it rubs off in very little time.
I'll have to order the replaceable buttons for the keypad linc, but it doesn'r appear there is anything for the remotelinc.
I use a computer printer and transparent/sticky media. Works on both remote and keypad. While the eventually wear, they last longer than most solutions, and are pretty easy to replace when necessary.
I mark all my paddles with transparent (actually frosted) Avery labels. They are small enough to work on paddles directly. Would have to do some trimming for an RL2 button. Print the labels on the PC, then transfer to the middle of the paddle where it does not get finger wear. Has worked well on my ICON devices. Not sure how well a label would hold up on a RL2 button where the label is subject to constant wear from finger pressure.
We use to label new electronics projects with dry transfer characters and coat them with clear coat of some kind. Don't remember exactly what we used but it was available from artist supplies.
For the original RemoteLinc that has a place to install a label. I used the custom label template on the sales page.
I have not tried to physically mark the buttons on it and don't have a RemoteLinc2 to play with.
