have an except in the actions
flemingmike
It is not a good idea to use My Lighting for All Off. There are some devices (thermostats can have set points changed, I/O Lincs can open garage doors) that do not react well to All Off. Also Insteon has no means of excluding selected Responders.
Define an ISY Scene and drag only those devices that should be turned Off. If the ISY is the Pro version there is an Icon toward the right end of the Icon list that turns On batch operations. All the Scene generation will be queued until batch mode is turned Off. This allows all the responders to be dragged to the Scene before link records are generated.
