February 23, 200818 yr #1 Will it be possible to control the Climate Control functions through the mentioned page in the MCE addin? (BTW mine quit working when I did the last upgrade)?? The next questions, I figured these are limitations of the adapter, but thought I would ask. Because you guys at UD have done majic to make devices to do things that the OEM claims is not possible! #2 I have the humidity sensor installed. Can anything be done with it? #3 I also plan to install an outdoor sensor, if it can be useful. #4 Will the be any way to control or monitor the inputs or outputs? #5 I also have UV lamps installed. The are features to notify you if the UV lamps or filter needs changed. It can also alert you if the drain pan fills. Will there there be any support for this stuff? Just need to know. trying to see if i can hit the limit on this thing!!!! Over 600 progs so far, wait till i get the security system started!
February 25, 200818 yr Hello ! My comments below. With kind regards, Michel #1 Will it be possible to control the Climate Control functions through the mentioned page in the MCE addin?(BTW mine quit working when I did the last upgrade)?? Yes ... the MCE plugin will be updated to support 2.7 as soon as it's officially released. The next questions, I figured these are limitations of the adapter, but thought I would ask. Because you guys at UD have done majic to make devices to do things that the OEM claims is not possible! #2 I have the humidity sensor installed. Can anything be done with it? #3 I also plan to install an outdoor sensor, if it can be useful. There's a command to retrieve the humidity sensor value but a) we haven't gotten it to work it's only polled #4 Will the be any way to control or monitor the inputs or outputs? Unfortunately, not! #5 I also have UV lamps installed. The are features to notify you if the UV lamps or filter needs changed. It can also alert you if the drain pan fills. Will there there be any support for this stuff? I am not sure if I follow. Is this an INSTEON device? Just need to know. trying to see if i can hit the limit on this thing!!!! Over 600 progs so far, wait till i get the security system started! O lord!
