Wait command
I just set up a new program to send alarms to my email address. The problem is when the If is true is sending emails every minute or so, and I want just get a email every hour the If is true. I tried the command "wait 1hour" having the same result. What am I doing wrong?
From 9:00:00AM
To 6:00:00PM
And Module 'Climate' Wind Speed >= 16 mph
Send notification to 'email' content 'Watch the wind'
Wait 1 hour
The Wait (and Repeat) statement allows the If to be reevaluated. Every time the wind speed exceeds the checked value the Program is triggered from the beginning and issues another email.
One solution is split the logic into two Programs. The second Program has a null If so that the Wait cannot cause the Program to be reevaluated.
Can you please post how to do it?
Program 1
From 9:00:00AM
To 6:00:00PM
Run Program ‘2’ (if)
Program 2
Wait 1 hour
Program 1
From 9:00:00AM
To 6:00:00PM
Program 2
Wait 1 hour
Thanks a lot, but I am still having the same result
Copy/Paste the two Programs. Right click a Program, select Copy to Clipboard (last option at bottom of list). They past into forum.
Make sure the Program changes have been saved by clicking Save Changes.
I already did it .I made two programs, my two programs look the same than your ones , but I got the same result than before.
My apologies. The Wait has no affect when there are no functional statements following the Wait.
Program 1
no change
Program 2
Disable Program '1'
Wait 1 hour
Enable Program '1'
Program 1
no change
Program 2
Disable Program '1'
Wait 1 hour
Enable Program '1'
This works perfect!!
Thanks and regards
Hi,
Just my 2 cents: You should set program 2 to run at startup. Otherwise, if you ever have a power outage or you reboot the ISY for whatever reason program 1 will remain disabled & program 2 will never run on it's own, thus you won't get any more emails.
Sent from my SPH-D710 using Tapatalk 2
