2477SA1 link problem
GregE
Delete the Load Controller from the ISY.
Factory reset the Load Controller.
Run Tools | Diagnostics | Event Viewer at Level 3.
Add the Load Controller to the ISY using New INSTEON Device. Enter the Insteon address, Name of your choice, and leave Device Type at default Auto Discover. Post the event trace.
There is a problem with the Load Controller that has occurred with multiple users. It is falsely NAKing commands. The event viewer will show if it is this problem or an actual communications problem.
Here it is
Sun 09/23/2012 10:13:04 AM : [1A C7 22 1 ] Start : Removing device from ISY
Sun 09/23/2012 10:13:04 AM : [1A C7 22 1 ] Finish : Removing from ISY was Successful
Sun 09/23/2012 10:13:05 AM : [All ] Writing 0 bytes to devices
Sun 09/23/2012 10:13:44 AM : [ 16 1D F4 1] DOF 0
Sun 09/23/2012 10:13:44 AM : [ 16 1D F4 1] ST 0
Sun 09/23/2012 10:13:45 AM : [ 16 27 56 1] DOF 0
Sun 09/23/2012 10:13:45 AM : [ 16 27 56 1] ST 0
Sun 09/23/2012 10:13:50 AM : [ 15 50 40 1] DON 0
Sun 09/23/2012 10:13:50 AM : [ 16 74 78 7] ST 255
Sun 09/23/2012 10:13:50 AM : [ 15 50 40 1] ST 255
Sun 09/23/2012 10:13:51 AM : [ 15 50 2D 1] DON 0
Sun 09/23/2012 10:13:51 AM : [ 16 74 78 8] ST 255
Sun 09/23/2012 10:13:51 AM : [ 15 50 2D 1] ST 255
Sun 09/23/2012 10:13:51 AM : [ 15 53 75 1] ST 255
Sun 09/23/2012 10:16:19 AM : [ 15 50 2D 1] DOF 0
Sun 09/23/2012 10:16:19 AM : [ 16 74 78 8] ST 0
Sun 09/23/2012 10:16:19 AM : [ 15 50 2D 1] ST 0
Sun 09/23/2012 10:16:19 AM : [ 15 53 75 1] ST 0
Sun 09/23/2012 10:16:22 AM : [ 15 50 40 1] DOF 0
Sun 09/23/2012 10:16:22 AM : [ 16 74 78 7] ST 0
Sun 09/23/2012 10:16:22 AM : [ 15 50 40 1] ST 0
Sun 09/23/2012 10:18:49 AM : ---- Initializing the linked devices ----
Sun 09/23/2012 10:18:49 AM : ---- All Linked Devices are now initialized ----
Sun 09/23/2012 10:18:49 AM : ---- Add remaining devices ----
Sun 09/23/2012 10:18:49 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 0D 00
Sun 09/23/2012 10:18:49 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 0D 00 06 (00)
Sun 09/23/2012 10:18:49 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 A7 0D FF (FF)
Sun 09/23/2012 10:18:49 AM : [standard-Direct Nack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:18:49 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Sun 09/23/2012 10:18:49 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Sun 09/23/2012 10:18:50 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 27 09 01 LNK-ON (01)
Sun 09/23/2012 10:18:50 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:18:50 AM : [LNK-BGN ] 02 64 01 00 06
Sun 09/23/2012 10:18:51 AM : [LNK-STAT ] 02 53 M(01) gid=00 1A.C7.22 090A 41
Sun 09/23/2012 10:18:51 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 0D 00
Sun 09/23/2012 10:18:51 AM : [LNK-END ] 02 65 06
Sun 09/23/2012 10:18:51 AM : [standard Msg. Handler] Unexpected Ack imCmd=65 cmd1= 0x22
Sun 09/23/2012 10:18:51 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 0D 00 06 (00)
Sun 09/23/2012 10:18:51 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 27 0D 02 (02)
Sun 09/23/2012 10:18:51 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:18:56 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 0D 00
Sun 09/23/2012 10:18:56 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 0D 00 06 (00)
Sun 09/23/2012 10:18:56 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 27 0D 02 (02)
Sun 09/23/2012 10:18:56 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:18:56 AM : [1A C7 22 0 ] Calibrating engine version
Sun 09/23/2012 10:18:56 AM : [1A C7 22 1 ] Adding device to ISY
Sun 09/23/2012 10:18:56 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 10 00
Sun 09/23/2012 10:18:56 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 10 00 06 ID-REQ (00)
Sun 09/23/2012 10:18:56 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 2B 10 00 ID-REQ (00)
Sun 09/23/2012 10:18:56 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:18:57 AM : [iNST-SRX ] 02 50 1A.C7.22 09.0A.41 8B 01 00 (00)
Sun 09/23/2012 10:18:57 AM : [standard-Broadcast][1A.C7.22-->09.0A.41] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:18:57 AM : [1A C7 22 1 ] Start : Adding device to ISY
Sun 09/23/2012 10:18:57 AM : [1A C7 22 1 ] Finish : Adding device to ISY was Successful
Sun 09/23/2012 10:18:57 AM : [1A C7 22 1 ] Link 0 : 0FF8 [E2011485D3FF1F01] Saving [E2011485D3FF1F01]
Sun 09/23/2012 10:18:57 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1
Sun 09/23/2012 10:18:57 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06 (00)
Sun 09/23/2012 10:18:57 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 2B 2E 00 (00)
Sun 09/23/2012 10:18:57 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:18:58 AM : [iNST-ERX ] 02 51 1A C7 22 14 85 D3 11 2E 00 01 01 00 00 20 00 1C FE 20 00 00 00 F8 00
Sun 09/23/2012 10:18:58 AM : [Extended-Direct][1A.C7.22-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 10:18:58 AM : [ 1A C7 22 1] OL 255
Sun 09/23/2012 10:18:58 AM : [ 1A C7 22 1] RR 28
Sun 09/23/2012 10:18:58 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 19 00
Sun 09/23/2012 10:18:58 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 19 00 06 LTSREQ (LIGHT)
Sun 09/23/2012 10:18:58 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 2B 01 FF (FF)
Sun 09/23/2012 10:18:58 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:18:58 AM : [ 1A C7 22 1] ST 255
Sun 09/23/2012 10:18:59 AM : [1A C7 22 1 ] Device added to ISY
Sun 09/23/2012 10:18:59 AM : ---- All Remaining Device Added ----
Sun 09/23/2012 10:18:59 AM : [iNST-TX-I1 ] 02 62 1A C7 22 0F 19 00
Sun 09/23/2012 10:18:59 AM : [iNST-ACK ] 02 62 1A.C7.22 0F 19 00 06 LTSREQ (LIGHT)
Sun 09/23/2012 10:19:00 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 27 01 FF (FF)
Sun 09/23/2012 10:19:00 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:19:00 AM : [ 1A C7 22 1] ST 255
Sun 09/23/2012 10:19:00 AM : [All ] Writing 8 bytes to devices
Sun 09/23/2012 10:19:00 AM : [1A C7 22 1 ] Link 0 : 0FF8 [E2011485D3FF1F01] Writing [E2011485D3FF1F01]
Sun 09/23/2012 10:19:00 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2F 00 00 02 0F FF 08 E2 01 14 85 D3 FF 1F 01 4B
Sun 09/23/2012 10:19:00 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2F 00 00 02 0F FF 08 E2 01 14 85 D3 FF 1F 01 4B 06 (00)
Sun 09/23/2012 10:19:01 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 27 2F 00 (00)
Sun 09/23/2012 10:19:01 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:19:01 AM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1A C7 22 09 0A 41 15
Sun 09/23/2012 10:19:01 AM : [PLM ] Group 1 : Writing Responder Link matching [1A C7 22 1 ] Link 0 : 0FF8 [E2011485D3FF1F01]
Sun 09/23/2012 10:19:01 AM : [1A C7 22 1 ] Link 1 : 0FF0 [0000000000000000] Writing [00..............]
Sun 09/23/2012 10:19:01 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1
Sun 09/23/2012 10:19:01 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1 06 (00)
Sun 09/23/2012 10:19:02 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 2B 2F 00 (00)
Sun 09/23/2012 10:19:02 AM : [standard-Direct Ack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:19:02 AM : [1A C7 22 1 ] Link 2 : 0FE8 : Writing High Water Byte
Sun 09/23/2012 10:19:02 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Sun 09/23/2012 10:19:02 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00)
Sun 09/23/2012 10:19:02 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 A7 2F FF (FF)
Sun 09/23/2012 10:19:02 AM : [standard-Direct Nack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:19:11 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Sun 09/23/2012 10:19:11 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00)
Sun 09/23/2012 10:19:12 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 AB 2F FF (FF)
Sun 09/23/2012 10:19:12 AM : [standard-Direct Nack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 10:19:21 AM : [iNST-TX-I2CS] 02 62 1A C7 22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Sun 09/23/2012 10:19:21 AM : [iNST-ACK ] 02 62 1A.C7.22 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00)
Sun 09/23/2012 10:19:21 AM : [iNST-SRX ] 02 50 1A.C7.22 14.85.D3 A7 2F FF (FF)
Sun 09/23/2012 10:19:21 AM : [standard-Direct Nack][1A.C7.22-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 10:19:25 AM : [ 1A C7 22 1] ERR 1
Thanks for the trace. That is the issue that is being attributed to the firmware in the latest Load Controller. The initial link record was written successfully so I think the Load Controller can be turned On and Off with the Admin Console or a Program.
Do a Show Device Links Table and post the results. If screen/window capture is not available post the saved XML file.
Run Tools | Diagnostics | Event Viewer with Level 3. Turn the Load Controller On and Off through the Admin Console and post the event trace.
This does not look like a problem the ISY can code around. The commands being issued are correct and the link record commands earlier in the trace worked. For some reason the Load Controller firmware decides to reject a valid command, reason unknown.
Another user did RMA the Load Controller and the new one had the same behavior. Presumably at the same firmware level so the results would be expected to be the same.
Hello all,
The only way that we got this to work was:
1. Make sure you are on automatic mode
2. Factory reset the Load Controller
3. Add it to ISY ... it may fail
4. If you see a node for the controller, right mouse click and then choose Diagnostics | Query Insteon Engine
No one has reported a problem with the NC variant of the Load Controller but I suspect they are not used as much as the NO. if you do switch to the NC keep in mind if something fails and the Load Controller reverts to its default NC state the load will be powered. Not a problem if that is not critical but I switched from an older NC Load Controller to a NO Load Controller because it was controlling a pump. I did not want the pump to accidently run dry because the Load Controller came up in the NC state.
GregE
Another user may have found a work around. After the device add fails, do a Restore Device on the Load Controller and see if it can then be controlled with the Admin Console.
Michel's suggestion didn't help. I was at my lake house and had already left to come home before seeing your last suggestion Lee. I disconnected it and brought it with me so I guess I will contact Smarthome and see if they are doing anything to fix it.
I am connecting it to my water heater so it doesn't run when I am away from the lake house. Using the NC version shouldn't be a problem for me.
Thanks for the help and suggestions. If you hear anything else, let me know.
Compensating for West coast time difference
Yes, they have found a work around. I suspect there will be more link records written before the End of List record is written. Regardless of approach wait for next Beta (3.3.3) estimated for end of week
