KPL 2486D Scenes won't correctly control local load
Hi,
I've got a room with 9 controlled loads (9 dimmers - either LampLinc, SwitchLinc). I can't get the Keypadlinc buttons B-H, to correctly act as scene controllers for the local 2486D KPL load (V.40 firmware). They always want to turn the load off rather than to the level I've programmed in the ISY. And yes, I've set the proper levels for the scene and for all controllers within that scene. I've done this before with older V.36 Keypadlincs, and it worked fine, but doesn't seem to work with the V.40. ISY software: started with 3.2.6, and then upgraded to 3.3.2. That didn't help.
First, before I got the KPL, I had everything working well with a RemoteLinc. The Remotelinc drove 6 scenes perfectly.
Then, I replaced one of the Switchlincs 2477D dimmers with a 2486D V.40 KPL dimmer, and tried to set up the same scenes that I had on the RemoteLinc on buttons B, C, D, E, F, and H of the new Keypadlinc. Button "A" (Main) was not used as a scene controller as it was the on/off for the local load.
I added the .1 button as a responder to all of the scenes . I added the B, C, D, E, F, and H buttons to each scene as a controller. I set the proper levels and ramp rate for the .1 local load in all of the scenes. And then I copied Scene attributes from the parent scene to each of the controllers, including the new KPL, verifying that every controller for every scene had the KPL's .1 local load set to the right brightness and ramp rate. I then programmed the 2485D KPL.
When I use the KPL to control the scenes, all devices go to the proper levels except the KPL's local load. It stays off. If I manually set the KPL local load to ON by pressing the upper left button, I can then select any of the programmed scene buttons, and the local load will turn off. So the local load is in the scenes, but it seems to be programmed to turn off when those scenes turn on rather than to the proper level.
If I use the RemoteLinc controller or the ISY to set the scenes, then all devices, including the KPL's local load, go to the right brightness.
The local load is set to turn on in scenes B, C, and D, but off in the others. I found that if, after programming, I went into each scene's settings for the KPL on the ISY, and re-adjusted the on level for that scene (say Scene B), then that scene button would work OK from the KPL. However, if I then went in and adjusted the level for Scene C in the ISY scene programming for the KPL, without changing anything for Scene B, then Scene C would start working, but now Scene B would turn off the local load again. It seems I was able to get 2 out of 3 of scenes B, C, and D to turn on the local load, but every time I got one to work, one of the others would quit working and would turn the local load off instead.
I had another KPL. I replace the first with the second, and the second KPL does the same thing. I did factory resets, Query Insteon Engine, and just about every combination of thing I could think of. I've verified that the device's links match the ISY's links by using the compare feature. They match. I've been working on this 4 or 5 hours, but nothing works.
Note: there are about 78-82 links on this device. Could that have something to do with it?
Any thoughts are appreciated.
Hello brookbphx,
This must be quite frustrating.
May I humbly request a simple test? If possible at all:
1. Remove the KPL from ISY
2. Do a factory reset on it
3. Make a scene with all the KPL buttons in that scene as follows
- Load: responder
- Others: controllers
4. For each controller, assign varying degrees of on level for the load (including off). i.e. start from button B all the way to H
Please do let me know what you get.
Hello Michel,
Well, I did what you asked me to. I completely removed the 2486D from the ISY. I factory reset the 2486D. I added the 2486D to the ISY with the Start Linking button. I then created 1 scene, adding the .1 load as a responder, and B-H as controllers. The 2486D was not added to any other scenes or programs. I set the levels of the .1 load to different brightnesses for each controller: e.g. B-90%, C-80%, etc. I then programmed the 2486D, and tried it out.
Result: Only the "Main" (Load) button will turn the load on. All other buttons will turn the load off.
Here's some additional info:
While waiting for a response, I installed another 2486D for another room that was simpler: 2 loads plus the load associated with the 2486D. I created 7 scenes. All buttons (except G) were used as scenes, including the .1 button. When .1 was pressed, all lights, including the local load went to bright. For the other buttons, there were various levels of brightness for the three different loads. This worked, and it worked well. There were around 38 links in the 2486D.
Then I decided to add in the other scene buttons to each scene as responders to turn all button LEDs off except the one that had been pressed. So, for example, the Scene for button C would set the local load to 60%, the other two loads to 50%, and the other 6 buttons to off. I programmed these buttons for each of the 7 scenes, and then reprogrammed. I went to test the scenes, and now I'm back to the original problem. The local load turns off for every scene except the upper left (Main .1 button). I looked at the number of links, and it was 63.
After doing the above, I decided to backtrack and set things back the way they were. I removed all of the 'other' buttons from each scene and reprogrammed. It didn't help. I factory reset the 2486D, and then reprogrammed. That didn't help either. I removed the 2486D from the ISY, factory reset it, readded it, and set it up identically to the way I first set it up that worked. That did not work. I verified how many links were in place. There were 38 like there were supposed to be, and the device matched the controller. But it still didn't work.
It seems that once you do something to 'break' it, like adding too many links, there's nothing you can do to fix it.
Slight update. I found that the C and G buttons did set the load to the right dim value, but B, D, E, and F all turned the load off even though they were programmed to set it on to particular dim levels.
Hi Michel,
Below is the log file from re-programming (restore) the device with this scene.
Settings for the .1 load in each of the other scenes are supposed to be as follows:
B-100%
C-88%
D-76%
E-65%
F-52%
G-40%
H-Off
I left the ramp rates at their default of .1sec
The KPL has buttons B-H set to Non-Toggle ON, while button .1 (A), the load/responder is set to toggle
I didn't tweak the controller button levels in the scenes. For whatever reason, in each button's scene, the default sliders for that scene are to turns On all of the other controller buttons, and turn off the button controller being pressed. For example, for the C button, when the 1C.8E.6E.C controller is selected in the tree, it shows the load at its dim level, button C as off, and all the rest of the buttons as On 100%
Here's the log:
Sun 09/23/2012 12:01:13 PM : [  1C 8E 6E 1] Preparing Device '1C.8E.6E.1' for Restore
Sun 09/23/2012 12:01:14 PM : [  1C 8E 6E 1] Device '1C.8E.6E.1' ready for Full Restore
Sun 09/23/2012 12:01:14 PM : [iNST-TX-I1  ] 02 62 1C 8E 6E 0F 0D 00
Sun 09/23/2012 12:01:14 PM : [iNST-ACK    ] 02 62 1C.8E.6E 0F 0D 00 06                 (00)
Sun 09/23/2012 12:01:14 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 0D 01           (01)
Sun 09/23/2012 12:01:14 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:14 PM : [1C 8E 6E 0  ] Calibrating engine version
Sun 09/23/2012 12:01:14 PM : [1C 8E 6E 0  ] May not fully support i2, reverting to i1
Sun 09/23/2012 12:01:14 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 FF 1F 08 F4
Sun 09/23/2012 12:01:14 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 FF 1F 08 F4 06        (00)
Sun 09/23/2012 12:01:15 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:15 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:15 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:15 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 07 FD
Sun 09/23/2012 12:01:15 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 07 FD 06        (00)
Sun 09/23/2012 12:01:16 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:16 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:16 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 FF 1F 06 06
Sun 09/23/2012 12:01:16 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:16 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 FF 1F 06 06 06        (00)
Sun 09/23/2012 12:01:17 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:17 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:17 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 FF 1F 05 0F
Sun 09/23/2012 12:01:17 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:17 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 FF 1F 05 0F 06        (00)
Sun 09/23/2012 12:01:18 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:18 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:18 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 FF 1F 04 18
Sun 09/23/2012 12:01:18 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 FF 1F 04 18 06        (00)
Sun 09/23/2012 12:01:19 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:19 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:19 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:19 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 FF 1F 03 21
Sun 09/23/2012 12:01:19 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 FF 1F 03 21 06        (00)
Sun 09/23/2012 12:01:20 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:20 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:20 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 FF 1F 02 2A
Sun 09/23/2012 12:01:20 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:20 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 FF 1F 02 2A 06        (00)
Sun 09/23/2012 12:01:21 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:21 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:21 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F C7 08 A2 47 13 21 82 FF 1F 01 33
Sun 09/23/2012 12:01:21 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F C7 08 A2 47 13 21 82 FF 1F 01 33 06        (00)
Sun 09/23/2012 12:01:22 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:22 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:22 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F BF 08 A2 00 13 21 82 FF 1F 01 82
Sun 09/23/2012 12:01:22 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:22 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F BF 08 A2 00 13 21 82 FF 1F 01 82 06        (00)
Sun 09/23/2012 12:01:23 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:23 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:23 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49
Sun 09/23/2012 12:01:23 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 06        (00)
Sun 09/23/2012 12:01:24 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:24 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:24 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F
Sun 09/23/2012 12:01:24 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:24 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F 06        (00)
Sun 09/23/2012 12:01:25 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:25 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:25 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55
Sun 09/23/2012 12:01:25 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 06        (00)
Sun 09/23/2012 12:01:26 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:26 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:26 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:26 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B
Sun 09/23/2012 12:01:26 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:26 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:26 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B 06        (00)
Sun 09/23/2012 12:01:27 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:27 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:27 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:27 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61
Sun 09/23/2012 12:01:27 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 06        (00)
Sun 09/23/2012 12:01:28 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:28 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:28 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:28 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67
Sun 09/23/2012 12:01:28 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 06        (00)
Sun 09/23/2012 12:01:29 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:29 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D
Sun 09/23/2012 12:01:29 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D 06        (00)
Sun 09/23/2012 12:01:29 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:29 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:30 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:30 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73
Sun 09/23/2012 12:01:30 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 06        (00)
Sun 09/23/2012 12:01:30 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:30 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:31 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:01:31 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41
Sun 09/23/2012 12:01:31 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 06        (00)
Sun 09/23/2012 12:01:31 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:31 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:31 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:01:31 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06        (00)
Sun 09/23/2012 12:01:32 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:33 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:01:33 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:33 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:01:33 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06        (00)
Sun 09/23/2012 12:01:33 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:33 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:33 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49
Sun 09/23/2012 12:01:33 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 06        (00)
Sun 09/23/2012 12:01:34 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:34 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:34 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:01:34 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06        (00)
Sun 09/23/2012 12:01:35 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:35 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:01:35 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:35 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E
Sun 09/23/2012 12:01:35 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E 06        (00)
Sun 09/23/2012 12:01:36 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:36 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:01:36 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06        (00)
Sun 09/23/2012 12:01:37 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:37 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:37 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:01:37 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:37 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF
Sun 09/23/2012 12:01:37 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF 06        (00)
Sun 09/23/2012 12:01:38 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:38 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:38 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:38 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:39 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:39 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:39 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 66 B0
Sun 09/23/2012 12:01:39 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 66 B0 06        (00)
Sun 09/23/2012 12:01:39 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:39 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:39 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:39 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:40 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:40 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:41 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 1B 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:41 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:41 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7
Sun 09/23/2012 12:01:41 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 06        (00)
Sun 09/23/2012 12:01:42 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:42 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:42 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:42 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:43 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:43 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:43 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:43 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 84 00 00 92
Sun 09/23/2012 12:01:43 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 84 00 00 92 06        (00)
Sun 09/23/2012 12:01:44 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:44 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:44 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:44 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:45 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:45 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:45 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:45 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7
Sun 09/23/2012 12:01:45 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 06        (00)
Sun 09/23/2012 12:01:46 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:46 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:46 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:47 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:47 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:47 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 A5 00 00 00 00 71
Sun 09/23/2012 12:01:47 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 A5 00 00 00 00 71 06        (00)
Sun 09/23/2012 12:01:47 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:47 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:47 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:47 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:48 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:48 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:48 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:48 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:48 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7
Sun 09/23/2012 12:01:48 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 06        (00)
Sun 09/23/2012 12:01:49 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:49 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:49 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:49 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:49 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:49 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:50 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:50 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:50 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:50 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:50 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 C1 00 00 00 00 00 00 55
Sun 09/23/2012 12:01:50 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 C1 00 00 00 00 00 00 55 06        (00)
Sun 09/23/2012 12:01:51 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:51 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:51 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:51 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:01:52 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:01:52 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:52 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7
Sun 09/23/2012 12:01:52 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 06        (00)
Sun 09/23/2012 12:01:52 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:52 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:52 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:52 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:01:53 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:01:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:01:53 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:53 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:53 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:53 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E
Sun 09/23/2012 12:01:53 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E 06        (00)
Sun 09/23/2012 12:01:54 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:54 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:54 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:54 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:01:55 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:55 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:55 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:55 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:55 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF
Sun 09/23/2012 12:01:55 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF 06        (00)
Sun 09/23/2012 12:01:56 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:56 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:56 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:56 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:01:57 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:57 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:57 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:57 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:57 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F
Sun 09/23/2012 12:01:57 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F 06        (00)
Sun 09/23/2012 12:01:58 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:58 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:58 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:58 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:01:58 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:01:58 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:01:58 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF
Sun 09/23/2012 12:01:58 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF 06        (00)
Sun 09/23/2012 12:01:59 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2F 00           (00)
Sun 09/23/2012 12:01:59 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:01:59 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7
Sun 09/23/2012 12:01:59 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 06        (00)
Sun 09/23/2012 12:02:00 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:00 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:00 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB
Sun 09/23/2012 12:02:00 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06        (00)
Sun 09/23/2012 12:02:01 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 08 02 7F 00 00 00 00 00 00 00 00 00 00 49
Sun 09/23/2012 12:02:01 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 08 02 7F 00 00 00 00 00 00 00 00 00 00 49 06        (00)
Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 07 02 BF 00 00 00 00 00 00 00 00 00 00 0A
Sun 09/23/2012 12:02:01 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 07 02 BF 00 00 00 00 00 00 00 00 00 00 0A 06        (00)
Sun 09/23/2012 12:02:01 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:02:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 06 02 DF 00 00 00 00 00 00 00 00 00 00 EB
Sun 09/23/2012 12:02:02 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 06 02 DF 00 00 00 00 00 00 00 00 00 00 EB 06        (00)
Sun 09/23/2012 12:02:02 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:02 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:02 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 05 02 EF 00 00 00 00 00 00 00 00 00 00 DC
Sun 09/23/2012 12:02:02 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 05 02 EF 00 00 00 00 00 00 00 00 00 00 DC 06        (00)
Sun 09/23/2012 12:02:03 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:03 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:03 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5
Sun 09/23/2012 12:02:12 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5
Sun 09/23/2012 12:02:12 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5 06        (00)
Sun 09/23/2012 12:02:13 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:13 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:13 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 03 02 FB 00 00 00 00 00 00 00 00 00 00 D2
Sun 09/23/2012 12:02:13 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 03 02 FB 00 00 00 00 00 00 00 00 00 00 D2 06        (00)
Sun 09/23/2012 12:02:13 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 02 02 FD 00 00 00 00 00 00 00 00 00 00 D1
Sun 09/23/2012 12:02:13 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 02 02 FD 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Sun 09/23/2012 12:02:14 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:14 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:14 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD
Sun 09/23/2012 12:02:14 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD 06        (00)
Sun 09/23/2012 12:02:15 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 2E 00           (00)
Sun 09/23/2012 12:02:15 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:02:15 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0
Sun 09/23/2012 12:02:15 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 06        (00)
Sun 09/23/2012 12:02:15 PM : [iNST-TX-I1  ] 02 62 1C 8E 6E 0F 24 00
Sun 09/23/2012 12:02:15 PM : [iNST-ACK    ] 02 62 1C.8E.6E 0F 24 00 06                 (00)
Sun 09/23/2012 12:02:16 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 2B 24 00           (00)
Sun 09/23/2012 12:02:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sun 09/23/2012 12:09:59 PM : [        Time] 12:10:34 0(0)
Once again, when any button is pressed other than the upper left .1 load button, the load turns off. Based on the strange default of all buttons on except the one pressed, as well as the 'non-toggle ON' setting for the buttons, all of the B-H buttons turn on.
So after doing the above, I decided to adjust the controller button's on/off levels for each controller, so that the controller button pressed would turn on, but the other controller buttons would turn off. (NOTE: I continued adding to this post, but exceeded my 60000 bytes, so see the next post for a continuation. . .
(Continued from previous post):
. . . So after doing the above, I decided to adjust the controller button's on/off levels for each controller, so that the controller button pressed would turn on, but the other controller buttons would turn off. So, for button G, for example, I slid the level for buttons B-F and H to 0%, and slid the level for button G to 100%. After getting them adjusted, I programmed the switch. After doing so, and trying out the switch, I found that all buttons B-H would turn the load off, and some of them acted a little strange as well. I went back to the ISY console, and looked at the programming. The on level for the load had reverted to 0% for every B-H controller. (Apparently it does this when you switch a controller's LED button, other than the one being programmed, from 100% to 0%, but it only shows the change when you leave the controller in the tree and come back to it). Additionally, the On/Off levels that I had set to 100% for the button being pressed had also reverted to 0%, and strangely, the Ramp Rate for the active controller button (which is grayed out for these controllers), showed a 9 minute ramp rate, while the ramp rate for all other controller buttons showed .1 second. I reset the load level to the previous levels indicated, and it seemed to stick when I went back and forth between the controllers in the tree. However, I could no longer set the active controller button to 100%. I'd set it to 100% on the screen, and it would show. But if I clicked on a different controller button in the tree, and then went back to the one I had just adjusted, it was back at 0%. Perhaps this is intended operation, but it sure seems strange. If this is the way it is supposed to work, this should be explained somewhere.
Anyway, after all of that, I programmed the KPL again and tried it out. Now, any B-H controller button that was pressed would turn on, and all of the other controller buttons would turn off. That part is good. However, pressing any of these buttons would turn the the load off rather than to the programmed dim level. I went back to the ISY console to validate the programming once again. This time, the load dim levels for each of the B-H scenes was correct on the screen. I checked the Device Links table against the ISY's table, and they matched, so the KPL was properly programmed as specified by the ISY. The Event Log for the programming is below:
Sun 09/23/2012 12:52:04 PM : [  1C 8E 6E 1] Preparing Device '1C.8E.6E.1' for Restore
Sun 09/23/2012 12:52:04 PM : [  1C 8E 6E 1] Device '1C.8E.6E.1' ready for Full Restore
Sun 09/23/2012 12:52:04 PM : [iNST-TX-I1  ] 02 62 1C 8E 6E 0F 0D 00
Sun 09/23/2012 12:52:04 PM : [iNST-ACK    ] 02 62 1C.8E.6E 0F 0D 00 06                 (00)
Sun 09/23/2012 12:52:04 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 0D 01           (01)
Sun 09/23/2012 12:52:04 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:04 PM : [1C 8E 6E 0  ] Calibrating engine version
Sun 09/23/2012 12:52:04 PM : [1C 8E 6E 0  ] May not fully support i2, reverting to i1
Sun 09/23/2012 12:52:04 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3
Sun 09/23/2012 12:52:04 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 06        (00)
Sun 09/23/2012 12:52:13 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3
Sun 09/23/2012 12:52:13 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 06        (00)
Sun 09/23/2012 12:52:16 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:16 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:16 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 00 1F 07 FC
Sun 09/23/2012 12:52:16 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 00 1F 07 FC 06        (00)
Sun 09/23/2012 12:52:17 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:17 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:17 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 00 1F 06 05
Sun 09/23/2012 12:52:17 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 00 1F 06 05 06        (00)
Sun 09/23/2012 12:52:18 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:18 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:18 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:52:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:52:18 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 00 1F 05 0E
Sun 09/23/2012 12:52:18 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 00 1F 05 0E 06        (00)
Sun 09/23/2012 12:52:19 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:19 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:19 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:19 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 00 1F 04 17
Sun 09/23/2012 12:52:19 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 00 1F 04 17 06        (00)
Sun 09/23/2012 12:52:20 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:20 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:20 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 00 1F 03 20
Sun 09/23/2012 12:52:21 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 00 1F 03 20 06        (00)
Sun 09/23/2012 12:52:21 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:21 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:21 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 00 1F 02 29
Sun 09/23/2012 12:52:22 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 00 1F 02 29 06        (00)
Sun 09/23/2012 12:52:22 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:22 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:22 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F C7 08 A2 00 13 21 82 FF 1F 01 7A
Sun 09/23/2012 12:52:23 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F C7 08 A2 00 13 21 82 FF 1F 01 7A 06        (00)
Sun 09/23/2012 12:52:23 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:23 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:23 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F BF 08 A2 47 13 21 82 FF 1F 01 3B
Sun 09/23/2012 12:52:24 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F BF 08 A2 47 13 21 82 FF 1F 01 3B 06        (00)
Sun 09/23/2012 12:52:24 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:25 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:25 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49
Sun 09/23/2012 12:52:25 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 06        (00)
Sun 09/23/2012 12:52:25 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:26 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:26 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F
Sun 09/23/2012 12:52:26 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F 06        (00)
Sun 09/23/2012 12:52:27 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:27 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:27 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:27 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55
Sun 09/23/2012 12:52:27 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 06        (00)
Sun 09/23/2012 12:52:28 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:28 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:28 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:28 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B
Sun 09/23/2012 12:52:28 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B 06        (00)
Sun 09/23/2012 12:52:29 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:29 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:29 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:29 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61
Sun 09/23/2012 12:52:29 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 06        (00)
Sun 09/23/2012 12:52:30 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:30 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:30 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:30 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67
Sun 09/23/2012 12:52:30 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 06        (00)
Sun 09/23/2012 12:52:31 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:31 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:31 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:31 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D
Sun 09/23/2012 12:52:31 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D 06        (00)
Sun 09/23/2012 12:52:32 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:32 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:32 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:52:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:52:32 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73
Sun 09/23/2012 12:52:32 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 06        (00)
Sun 09/23/2012 12:52:33 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:33 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:33 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1C 8E 6E 01 1C 40 15
Sun 09/23/2012 12:52:33 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41
Sun 09/23/2012 12:52:33 PM : [iNST-ERX    ] 02 51 1C 8A 6C 13 21 82 B1 A1 80 62 4D FD F2 FD E2 15 1B 32 A3 7D E0 14 C7
Sun 09/23/2012 12:52:33 PM : [standard-Direct Nack][1C.8A.6C-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:34 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 06        (00)
Sun 09/23/2012 12:52:34 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:34 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:34 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:52:34 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06        (00)
Sun 09/23/2012 12:52:35 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:35 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:52:35 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:35 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:52:35 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06        (00)
Sun 09/23/2012 12:52:36 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:36 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52
Sun 09/23/2012 12:52:36 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:36 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49
Sun 09/23/2012 12:52:36 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 06        (00)
Sun 09/23/2012 12:52:37 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:37 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:52:37 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06        (00)
Sun 09/23/2012 12:52:38 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:52:38 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:52:38 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:52:38 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:38 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E
Sun 09/23/2012 12:52:38 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E 06        (00)
Sun 09/23/2012 12:52:39 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:39 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:39 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:52:39 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06        (00)
Sun 09/23/2012 12:52:40 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:40 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:40 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17
Sun 09/23/2012 12:52:40 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:40 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF
Sun 09/23/2012 12:52:40 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF 06        (00)
Sun 09/23/2012 12:52:41 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:41 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:41 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:41 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:42 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:42 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:42 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:42 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:42 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 33 E3
Sun 09/23/2012 12:52:42 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 33 E3 06        (00)
Sun 09/23/2012 12:52:43 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:43 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:43 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:44 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:44 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:44 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:44 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:44 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7
Sun 09/23/2012 12:52:44 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 06        (00)
Sun 09/23/2012 12:52:45 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:45 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:45 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:46 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:47 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:47 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:47 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 66 00 00 B0
Sun 09/23/2012 12:52:47 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 66 00 00 B0 06        (00)
Sun 09/23/2012 12:52:47 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:47 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:47 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:48 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:52:48 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:52:49 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:49 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:49 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7
Sun 09/23/2012 12:52:49 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 06        (00)
Sun 09/23/2012 12:52:50 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:50 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:50 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:50 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2F 00           (00)
Sun 09/23/2012 12:52:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:52:51 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:51 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:51 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 84 00 00 00 00 92
Sun 09/23/2012 12:52:51 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 84 00 00 00 00 92 06        (00)
Sun 09/23/2012 12:52:51 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:51 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:51 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:51 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:52 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:52 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:52 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:52 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:52 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7
Sun 09/23/2012 12:52:52 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 06        (00)
Sun 09/23/2012 12:52:53 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:53 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:53 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:54 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:54 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:54 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 A5 00 00 00 00 00 00 71
Sun 09/23/2012 12:52:54 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 A5 00 00 00 00 00 00 71 06        (00)
Sun 09/23/2012 12:52:55 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:55 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:55 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:55 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06        (00)
Sun 09/23/2012 12:52:56 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:56 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:57 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F
Sun 09/23/2012 12:52:57 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:52:57 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7
Sun 09/23/2012 12:52:57 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 06        (00)
Sun 09/23/2012 12:52:57 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:57 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:57 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:52:57 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:52:58 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:58 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:58 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:52:58 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:52:58 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E
Sun 09/23/2012 12:52:59 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E 06        (00)
Sun 09/23/2012 12:52:59 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:52:59 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:52:59 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:52:59 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:53:00 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:00 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:01 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:53:01 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:53:01 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF
Sun 09/23/2012 12:53:01 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF 06        (00)
Sun 09/23/2012 12:53:01 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:01 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:53:01 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:53:02 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:02 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:02 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:53:02 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sun 09/23/2012 12:53:02 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F
Sun 09/23/2012 12:53:02 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F 06        (00)
Sun 09/23/2012 12:53:03 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:03 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:03 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:53:03 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06        (00)
Sun 09/23/2012 12:53:04 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:04 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:05 PM : [iNST-ERX    ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27
Sun 09/23/2012 12:53:05 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Sun 09/23/2012 12:53:05 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF
Sun 09/23/2012 12:53:05 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF 06        (00)
Sun 09/23/2012 12:53:05 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2F 00           (00)
Sun 09/23/2012 12:53:05 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:05 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7
Sun 09/23/2012 12:53:05 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 06        (00)
Sun 09/23/2012 12:53:06 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:06 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:06 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 08 03 7E 00 00 00 00 00 00 00 00 00 00 49
Sun 09/23/2012 12:53:06 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 08 03 7E 00 00 00 00 00 00 00 00 00 00 49 06        (00)
Sun 09/23/2012 12:53:07 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:07 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:07 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 07 03 BE 00 00 00 00 00 00 00 00 00 00 0A
Sun 09/23/2012 12:53:07 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 07 03 BE 00 00 00 00 00 00 00 00 00 00 0A 06        (00)
Sun 09/23/2012 12:53:07 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:07 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:07 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 06 03 DE 00 00 00 00 00 00 00 00 00 00 EB
Sun 09/23/2012 12:53:07 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 06 03 DE 00 00 00 00 00 00 00 00 00 00 EB 06        (00)
Sun 09/23/2012 12:53:08 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:08 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:08 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 05 03 EE 00 00 00 00 00 00 00 00 00 00 DC
Sun 09/23/2012 12:53:08 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 05 03 EE 00 00 00 00 00 00 00 00 00 00 DC 06        (00)
Sun 09/23/2012 12:53:09 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:09 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:09 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 04 03 F6 00 00 00 00 00 00 00 00 00 00 D5
Sun 09/23/2012 12:53:09 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 04 03 F6 00 00 00 00 00 00 00 00 00 00 D5 06        (00)
Sun 09/23/2012 12:53:10 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:10 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:10 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 03 03 FA 00 00 00 00 00 00 00 00 00 00 D2
Sun 09/23/2012 12:53:10 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 03 03 FA 00 00 00 00 00 00 00 00 00 00 D2 06        (00)
Sun 09/23/2012 12:53:10 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 02 03 FC 00 00 00 00 00 00 00 00 00 00 D1
Sun 09/23/2012 12:53:10 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 02 03 FC 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Sun 09/23/2012 12:53:11 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:11 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:11 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB
Sun 09/23/2012 12:53:11 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06        (00)
Sun 09/23/2012 12:53:12 PM : [iNST-SRX    ] 02 50 2C.EE.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:12 PM : [standard-Direct Ack][2C.EE.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:12 PM : [iNST-DUP    ] Previous message ignored.
Sun 09/23/2012 12:53:21 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB
Sun 09/23/2012 12:53:21 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06        (00)
Sun 09/23/2012 12:53:21 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:21 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 08 02 01 00 00 00 00 00 00 00 00 00 00 C7
Sun 09/23/2012 12:53:21 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 08 02 01 00 00 00 00 00 00 00 00 00 00 C7 06        (00)
Sun 09/23/2012 12:53:22 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:22 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 07 02 01 00 00 00 00 00 00 00 00 00 00 C8
Sun 09/23/2012 12:53:22 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 07 02 01 00 00 00 00 00 00 00 00 00 00 C8 06        (00)
Sun 09/23/2012 12:53:23 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:23 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 06 02 01 00 00 00 00 00 00 00 00 00 00 C9
Sun 09/23/2012 12:53:23 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 06 02 01 00 00 00 00 00 00 00 00 00 00 C9 06        (00)
Sun 09/23/2012 12:53:23 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:23 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 05 02 01 00 00 00 00 00 00 00 00 00 00 CA
Sun 09/23/2012 12:53:23 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 05 02 01 00 00 00 00 00 00 00 00 00 00 CA 06        (00)
Sun 09/23/2012 12:53:24 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:24 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 04 02 01 00 00 00 00 00 00 00 00 00 00 CB
Sun 09/23/2012 12:53:24 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 04 02 01 00 00 00 00 00 00 00 00 00 00 CB 06        (00)
Sun 09/23/2012 12:53:25 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:25 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC
Sun 09/23/2012 12:53:25 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC 06        (00)
Sun 09/23/2012 12:53:34 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC
Sun 09/23/2012 12:53:34 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC 06        (00)
Sun 09/23/2012 12:53:35 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:35 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 02 02 01 00 00 00 00 00 00 00 00 00 00 CD
Sun 09/23/2012 12:53:35 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 02 02 01 00 00 00 00 00 00 00 00 00 00 CD 06        (00)
Sun 09/23/2012 12:53:36 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 2E 00           (00)
Sun 09/23/2012 12:53:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sun 09/23/2012 12:53:36 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD
Sun 09/23/2012 12:53:36 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD 06        (00)
Sun 09/23/2012 12:53:36 PM : [iNST-TX-I2  ] 02 62 1C 8E 6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0
Sun 09/23/2012 12:53:36 PM : [iNST-ACK    ] 02 62 1C.8E.6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 06        (00)
Sun 09/23/2012 12:53:37 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 27 2E 00           (00)
Sun 09/23/2012 12:53:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 09/23/2012 12:53:37 PM : [iNST-TX-I1  ] 02 62 1C 8E 6E 0F 24 00
Sun 09/23/2012 12:53:37 PM : [iNST-ACK    ] 02 62 1C.8E.6E 0F 24 00 06                 (00)
Sun 09/23/2012 12:53:37 PM : [iNST-SRX    ] 02 50 1C.8E.6E 13.21.82 23 24 00           (00)
Sun 09/23/2012 12:53:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
So now, the big question is: what is going on? Why won't the load be controlled correctly? Why does the ISY software lose the load's dim settings (reset to 0%) when one of the controllers LED's is switched from 100% to 0%? Why can't I program the active controller LED back to 100% and have it stick? Why does the grayed out ramp rate for the active controller say that it's a 9 minute ramp?
It's just very confusing.
Thanks for the help!
Attached are some screen captures to show the contents of the test scene, and the scene settings for the "C" button's levels. As you can see, Scene C has all buttons set to a 0% level, but button C's ramp rate is 9 minutes and grayed out. You can also see that the load is set to 88%. However, pressing button C turns the load off instead of setting it to 88%.
Not addressing the load button reaction, trying to recreate that here.
A Secondary KPL button has no Ramp Rate. A Secondary button does not ramp up or ramp down. It is simply On or Off which is why the Ramp Rate sliders are grayed out. The 9 minute ramp rate indicates some field in the ISY configuration has a value of 00 (9 minute ramp rate) rather than the conventional 1F which is .1 seconds. The value has no meaning for a Secondary KPL button.
Hi Lee,
Yes, I understand that 'on/off' type devices, such as relay switches and LED buttons have no ramp rate. I was just trying to show the symptoms and to indicate that they seemed strange. I'm wondering if anyone knows why either A) the ISY, or B) the KPL shows the ramp rate as 9 minutes? What is the point in that? And it's only 9 minutes for the active controller button. All of the 'responder' buttons for that controller group have their ramp rate set to .1 sec. It doesn't bother me particularly that the ramp rate shows as 9 minutes, because in reality the button doesn't ramp - it switches immediately. However, if software in the ISY or in the 2486D is setting that byte incorrectly, and that is causing another unexpected problem elsewhere, then it is of concern. So since it was 'strange', I thought it would be good to report it. Sometimes little quirks like that can provide an 'aha' moment to a programmer, when they realize that perhaps the wrong byte was set in some location. Maybe that ramp rate byte getting set to 0x00 should not be happening, and when it happens, it is causing something else to not work right.
Thanks for trying to reproduce this and help me out!
Are you holding all the Scene updates, doing all the physical KPL changes at once?
Usually, I will turn off "Automatically Write Changes", make all my scene edits, and then turn Auto write back on.
Thanks. I thought that was the sequence. I did that I have not been able to recreate the functional problems reported. Using an 8 button KPL Dimmer with v40 firmware, created 7 Scenes one for each Secondary button. Each of the 7 Scenes was assigned one of the Secondary buttons as Controller, with all the other buttons, including the load (Main A) as Responders. Set all the responders to 0% On except the Main A which has a different On level for each Scene.
SceneB - Main at 90%
SceneC - Main at 80%
SceneD - Main at 70%
SceneE - Main at 60%
SceneF - Main at 50%
SceneG - Main at 40%
SceneH - Main at 30%
Pressing Main turns the load on to 100%, each press of the Secondary buttons, B,C,D,E,F,G,H reduces the load by 10%.
I did recreate the Ramp Rate at 9 minutes. Since the Secondary Ramp Rate sliders have no functional aspect the values have no adverse affects.
I will now set the Secondary buttons to non-toggle On mode which should have no functional change except the buttons will blink twice when pressed.
Thanks Lee,
You may recall way back in this thread that I said that I originally got the KPL to work correctly for my scene (Not the test scene as requested by Michel, but the original working scene needed for this house). The buttons would all turn on the load as intended. There were two other Switchlincs on each scene, for a total of 3 responders. I had not yet added in the other KPL buttons as responders to each scene, so all the buttons would stay lit. But at least the load could be controlled. I think there were 38 total links on the KPL after setting it that way.
Next, I did add each of the other KPL buttons as responders to each scene so that I could get them to turn off when I pressed a Scene button. That's when things broke for that KPL, and I've never been able to get them working again. There were 63 device links in that case.
My theory is that the KPL will work OK until you've either got too many links or until you set other KPL buttons as responders to a KPL controller button. Given that SmartHome was trying to resolve an issue with turning off all buttons except the pressed button om mutually exclusive scene buttons with multiple separate controllers, I wouldn't be too surprised if they accidentally sneaked in a bug to turn off the load as well as the other buttons.
In this quest to get these KPLs working, I've now got 3 KPLs that won't control the load to any ON level from buttons B-H.
No amount of factory resetting, removing from ISY and readding, or even creating completely new scenes to add it to helps.
I've got one more brand new KPL in a box, but I hesitate to 'load it up' and break it like I've now broken 3 others.
How is the KPL factory reset being performed?
Remove power by pulling set button. Wait 10 seconds or so. Push button back in and hold until switch beeps. Hold another couple of seconds and release. The load turns on full bright.
I haven't gone in and queried the links after doing so. Perhaps I should do that to make sure they're being wiped out.
Might be worth a try. I've not heard of a condition that cannot be cleared with a factory reset.
  • 1 month later...
I'm experiencing the same issue with release 3.3.4 and a 2486D v.41. Any updates on this?
