Can't add EZIO8SA to ISY99 3.3.2
AlX
I am having difficulties with adding EZIO8SA that is using EZIOComm. Trying to add it manually as well (and yes ISY detects type correct if I do not chose type). Always in the end getting this:
The following devices could not be added:
xx.xx.xx Compacta EZIO8SA: INSTEON I/O Controller v.00
- Cannot determine device link table address
I can communicate with EZIO8SA using program from Simplehomenet. What am I doing wrong?
Regards,
Alex
Run | Tools | Diagnostics | Event Viewer at Level 3.
Use New INSTEON Device, enter Insteon Address, Name of your choice, with Device Type at default Auto Discover. Post the event trace.
Here is what I got:
Tue 09/25/2012 08:25:21 : [1b 2 c3 ] Added to list of devices to link to ISY
Tue 09/25/2012 08:25:21 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 0D 00
Tue 09/25/2012 08:25:21 : [iNST-ACK ] 02 62 1B.02.C3 0F 0D 00 06 (00)
Tue 09/25/2012 08:25:22 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 0D 01 (01)
Tue 09/25/2012 08:25:22 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:22 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 10 00
Tue 09/25/2012 08:25:22 : [iNST-ACK ] 02 62 1B.02.C3 0F 10 00 06 ID-REQ (00)
Tue 09/25/2012 08:25:22 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 10 00 ID-REQ (00)
Tue 09/25/2012 08:25:22 : [iNST-SRX ] 02 50 1B.02.C3 07.04.FF 87 01 00 (00)
Tue 09/25/2012 08:25:22 : [standard-Broadcast][1B.02.C3-->07.04.FF] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:22 : [1B 2 C3 0 ] Calibrating engine version
Tue 09/25/2012 08:25:22 : [1B 2 C3 0 ] May not fully support i2, reverting to i1
Tue 09/25/2012 08:25:22 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Tue 09/25/2012 08:25:22 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Tue 09/25/2012 08:25:23 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Tue 09/25/2012 08:25:23 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:23 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:23 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:23 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B FF PEEK (FF)
Tue 09/25/2012 08:25:23 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 01
Tue 09/25/2012 08:25:23 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 01 06 SET-MSB(01)
Tue 09/25/2012 08:25:24 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 01 SET-MSB(01)
Tue 09/25/2012 08:25:24 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:24 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:24 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:24 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 2B 2B 00 PEEK (00)
Tue 09/25/2012 08:25:24 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 09/25/2012 08:25:24 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 3F
Tue 09/25/2012 08:25:24 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 3F 06 SET-MSB(3F)
Tue 09/25/2012 08:25:25 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 2B 28 3F SET-MSB(3F)
Tue 09/25/2012 08:25:25 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 09/25/2012 08:25:25 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:25 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:25 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 03 PEEK (03)
Tue 09/25/2012 08:25:25 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:25 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Tue 09/25/2012 08:25:25 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Tue 09/25/2012 08:25:26 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Tue 09/25/2012 08:25:26 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:26 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:26 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:26 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 01 PEEK (01)
Tue 09/25/2012 08:25:26 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 01
Tue 09/25/2012 08:25:26 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 01 06 POKE (01)
Tue 09/25/2012 08:25:27 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 29 01 POKE (01)
Tue 09/25/2012 08:25:27 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:27 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 1F
Tue 09/25/2012 08:25:27 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 1F 06 SET-MSB(1F)
Tue 09/25/2012 08:25:27 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 1F SET-MSB(1F)
Tue 09/25/2012 08:25:27 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:27 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:28 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 02 PEEK (02)
Tue 09/25/2012 08:25:28 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:28 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 02
Tue 09/25/2012 08:25:28 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 02 06 POKE (02)
Tue 09/25/2012 08:25:28 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 2B 29 02 POKE (02)
Tue 09/25/2012 08:25:28 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 09/25/2012 08:25:28 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 3F
Tue 09/25/2012 08:25:28 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 3F 06 SET-MSB(3F)
Tue 09/25/2012 08:25:29 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 3F SET-MSB(3F)
Tue 09/25/2012 08:25:29 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:29 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:29 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:29 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 03 PEEK (03)
Tue 09/25/2012 08:25:29 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 03
Tue 09/25/2012 08:25:29 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 03 06 POKE (03)
Tue 09/25/2012 08:25:30 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 29 03 POKE (03)
Tue 09/25/2012 08:25:30 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:30 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Tue 09/25/2012 08:25:30 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Tue 09/25/2012 08:25:30 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Tue 09/25/2012 08:25:30 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:30 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:31 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 01 PEEK (01)
Tue 09/25/2012 08:25:31 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:31 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 01
Tue 09/25/2012 08:25:31 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 01 06 SET-MSB(01)
Tue 09/25/2012 08:25:31 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 01 SET-MSB(01)
Tue 09/25/2012 08:25:31 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Tue 09/25/2012 08:25:31 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Tue 09/25/2012 08:25:32 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 00 PEEK (00)
Tue 09/25/2012 08:25:32 : [standard-Direct Ack][1B.02.C3-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Tue 09/25/2012 08:25:32 : [1B 2 C3 0 ] Failed to add device
Regards,
Alex
Thanks for getting the trace data. It looks like the I2CS work that was added at 3.3.x to support SHN I2CS devices has impacted the non I2CS path. I've sent a note to UDI tech support explaining the problem.
Thanks for prompt response, Lee.
So I understand to add it I need to roll back to 3.2.x or even farther back? Will I be able to use it once it is added? Or the only solution is just simply wait for an updates?
Regards,
Alex
I don't know if this was introduced at 3.3.1 or 3.3.2. Going back to 3.2.6 will allow the EZIO8SA to be added. However, the 3.3.2 update changed the configuration information such that it is not backward compatible with 3.2.6. I will be necessary to restore a good 3.2.6 backup once the older firmware has been installed.
If you can wait a few days the 3.3.2 issue seems pretty straight forward. There is a new beta coming out at the end of the week (projected anyway). Perhaps this can be resolved by then. UDI is on the West coast so there is some time zone delay in seeing the forum information.
Still no go. Here is the log:
Thu 10/04/2012 23:03:36 : [1b 2 c3 ] Added to list of devices to link to ISY
Thu 10/04/2012 23:03:36 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 0D 00
Thu 10/04/2012 23:03:36 : [iNST-ACK ] 02 62 1B.02.C3 0F 0D 00 06 (00)
Thu 10/04/2012 23:03:36 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 0D 01 (01)
Thu 10/04/2012 23:03:36 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:36 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 10 00
Thu 10/04/2012 23:03:36 : [iNST-ACK ] 02 62 1B.02.C3 0F 10 00 06 ID-REQ (00)
Thu 10/04/2012 23:03:37 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 10 00 ID-REQ (00)
Thu 10/04/2012 23:03:37 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:37 : [iNST-SRX ] 02 50 1B.02.C3 07.04.FF 87 01 00 (00)
Thu 10/04/2012 23:03:37 : [std-Broadcast] 1B.02.C3-->07.04.FF, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:37 : [1B 2 C3 0 ] Calibrating engine version
Thu 10/04/2012 23:03:37 : [1B 2 C3 0 ] May not fully support i2, reverting to i1
Thu 10/04/2012 23:03:37 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Thu 10/04/2012 23:03:37 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Thu 10/04/2012 23:03:37 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Thu 10/04/2012 23:03:37 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:37 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:38 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B FF PEEK (FF)
Thu 10/04/2012 23:03:38 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:38 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 1F
Thu 10/04/2012 23:03:38 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 1F 06 SET-MSB(1F)
Thu 10/04/2012 23:03:38 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 1F SET-MSB(1F)
Thu 10/04/2012 23:03:38 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:38 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:39 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 02 PEEK (02)
Thu 10/04/2012 23:03:39 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:39 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 3F
Thu 10/04/2012 23:03:39 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 3F 06 SET-MSB(3F)
Thu 10/04/2012 23:03:39 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 3F SET-MSB(3F)
Thu 10/04/2012 23:03:39 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:39 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:40 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 03 PEEK (03)
Thu 10/04/2012 23:03:40 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:40 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Thu 10/04/2012 23:03:40 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Thu 10/04/2012 23:03:40 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Thu 10/04/2012 23:03:40 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:40 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:41 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 01 PEEK (01)
Thu 10/04/2012 23:03:41 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:41 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 01
Thu 10/04/2012 23:03:41 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 01 06 POKE (01)
Thu 10/04/2012 23:03:41 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 29 01 POKE (01)
Thu 10/04/2012 23:03:41 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 1F
Thu 10/04/2012 23:03:41 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 1F 06 SET-MSB(1F)
Thu 10/04/2012 23:03:42 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 1F SET-MSB(1F)
Thu 10/04/2012 23:03:42 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:42 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:42 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:42 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 02 PEEK (02)
Thu 10/04/2012 23:03:42 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 02
Thu 10/04/2012 23:03:42 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 02 06 POKE (02)
Thu 10/04/2012 23:03:43 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 29 02 POKE (02)
Thu 10/04/2012 23:03:43 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:43 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 3F
Thu 10/04/2012 23:03:43 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 3F 06 SET-MSB(3F)
Thu 10/04/2012 23:03:43 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 3F SET-MSB(3F)
Thu 10/04/2012 23:03:44 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:44 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:44 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:44 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 03 PEEK (03)
Thu 10/04/2012 23:03:44 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 29 03
Thu 10/04/2012 23:03:44 : [iNST-ACK ] 02 62 1B.02.C3 0F 29 03 06 POKE (03)
Thu 10/04/2012 23:03:44 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 29 03 POKE (03)
Thu 10/04/2012 23:03:44 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 0F
Thu 10/04/2012 23:03:44 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 0F 06 SET-MSB(0F)
Thu 10/04/2012 23:03:45 : CLI-WBug: Connecting to datafeed.weatherbug.com
Thu 10/04/2012 23:03:45 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 0F SET-MSB(0F)
Thu 10/04/2012 23:03:45 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:45 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:45 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:45 : CLI-WBug: Successfully Processed WBug Response
Thu 10/04/2012 23:03:45 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 01 PEEK (01)
Thu 10/04/2012 23:03:45 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 28 1F
Thu 10/04/2012 23:03:45 : [iNST-ACK ] 02 62 1B.02.C3 0F 28 1F 06 SET-MSB(1F)
Thu 10/04/2012 23:03:46 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 28 1F SET-MSB(1F)
Thu 10/04/2012 23:03:46 : [std-Direct Ack] 1B.02.C3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 10/04/2012 23:03:46 : [iNST-TX-I1 ] 02 62 1B 02 C3 0F 2B FF
Thu 10/04/2012 23:03:46 : [iNST-ACK ] 02 62 1B.02.C3 0F 2B FF 06 PEEK (FF)
Thu 10/04/2012 23:03:46 : [iNST-SRX ] 02 50 1B.02.C3 19.6E.B7 27 2B 02 PEEK (02)
Thu 10/04/2012 23:03:46 : [1B 2 C3 0 ] Failed to add device
Turns out there were two problems at 3.3.2. One was resolved at 3.3.3. The second was not visible until the first was fixed. I have tested a 3.3.4 Alpha with the second fix. Have been able to successfully add several different variants of EZIOxx I2 devices. The very newest I2CS EZIOxx devices work on 3.3.2 and 3.3.3
Ah well. Luckily, other things (that I hope will work) to soothe my itch, came. Will have to wait till 3.3.4 now.
      37.1k
      371.5k
