Program help
I have a simple KPL/AL scene that I want to do the following. If I turn off the scene in the evening, i want it to come on at 11:00 PM. If I turn it off after 10 PM I want it to come back on in an hour after turning off (say turn it off at 10:30PM, come back on at 11:30, OR if turned off at say 11:30PM that it comes back on at 12:30AM.). The hour rule can be in place till sunrise the next day(But I want the scene on all the time unless I turn it off). How should I write the program(s) to make that work?
Thank you!
Never mind, I got it. For those who are curious, I created a folder with a time frame of 10PM to Sunrise. 3 programs; 1 is If the module is off at 10:01, then start program 2, which is if the module is switched off, then wait an hour and switch it back on. The third program is if the module is switched on, stop the second program.
Hello mcrean,
I am so very sorry for the delay in replying to you ... it seems that you have found the answer.
Please let us know if we can be of further assistance,
